Question about Vivitek V37835 46 in. LCD Television
Flat sceen tv
My tv will cut on for about 10min and then shut off something i have to wait and than turn it back on but after a few min it shuts off again.
  • jhyman9 Dec 13, 2008
    I have the same problem - I usually have to turn it off and then on again several times before it "takes". Spoke to repairman and he is puzzled also.
  • Anonymous Mar 14, 2009
    Same problem. Five times on and off @ ten minute intervals. Then it will play all night.
If it's a DLP, I've noticed the air vents for ventilation in the bulb housing were not opened all the way when I replaced my bulb. The vents closed too much will cause the bulb to get hot and shut down the system. Try removing the bulb housing and opening the vents as much as possible to allow appropriate air flow. This solved my problem.
Posted on Dec 29, 2008
My Panasonic led tv just shuts off , wait 10 mins
It could be the room temperature or the TV is placed in a box type cabinet, thus restricting the air circulation at the back of the TV. Flat screen TV's generate a lot of heat and without proper air circulation, they usually shut down to prevent damage to its components. Are you in the middle of a cold spell? Usually when it's cold, you have the heaters on hi heat, yes? Try and reduce the heat or place the TV on a cabinet with ample air circulation and then see the difference.
Oct 17, 2014 | Televison & Video
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Lcd tv shuts off by itself and then turns on by itself
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
Dec 27, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My TV won't come back on.
the fuse on the main board is blown.replace that fuse.
Nov 14, 2008 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Vivitek V37835 46 in. LCD Television Logo
212 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
