Question about Maytag Atlantis MAV9750A Top Load Washer
Washing machine on laminate flooring
We put down laminate flooring in our laundry room. When we put the washer back in it started to vibrate and moving. The flooring is a floating floor. We have tried rubber pieces under legs, that did not work. The washer is level. Any ideas about what we should do? Thanks for your time
  • stuck123 Jun 16, 2008
    washing machine on tiles moving violently and vibrating, pls help, tried rubber under feet.
  • Anonymous Oct 03, 2013
    I don't know what to do about my washing machine on laminate flooring in Phoenix. Do you know what would go good under to stable it?
    Genius:
  • 1,554 Answers
Drill small plug holes to let the washer set on the concrete
Posted on Feb 13, 2008
Recently moved our laundry room from 1st to 2nd floor, not realizing that front load washers are not good for the 2nd floor...
look the really heavy duty floor pads used in horse stables very dense and thicker than anti vib because even it restacked extra weight wont stop the vibration
Jul 27, 2016 | LG Washing Machines
Leveled washer gets out of balance when load in spin cycle
A vibration problem is about the hardest thing to diagnose long distance but I will give you the most common things to look for.
Shipping brackets and materials not removed from the machine. You should be able to move the basket around easily by hand. Go over the installation instructions and make sure everything has been removed.
Leveling legs and lock nuts misadjusted or loose. You want the legs adjusted as low to the floor as possible. The higher it sits, the more movement it has.
Weak floor. If you can stomp the floor and have pictures rattle on the wall, you will have vibration problems with the washer. If it is on a laminate hardwood floor, you will have vibration problems. These floors have too much bounce for a washing machine.
The tub support to stiff causing too much vibration to be transferred to the cabinet or not allowing the tub/basket to return to the upright position so that it starts an out of balance spin. Put the washer into a cycle and let it agitate. Before it goes into a spin, open the lid and see if it is leaning awkwardly to one side. If the washer has some years on it, this may be your problem. If you remove the front panel you will see the thick washer the whole unit sits on. If it seems the unit is stiff , you may try spraying a LITTLE wd40 on the base it sits on so it slides easier, but just a little.
Check these things out and you should find your problem.
Thanks/Mike
Oct 24, 2007 | Washing Machines
Tip
Front Loader Excessive Vibration
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk.
Some of the early manufactured shock absorbers, weren't up to par and were uable to maintain the washer suspension over continuous use. The manufacturer's improved the shock absorbers to make them more stiff and minimize vibration. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
If the washer is mounted on a pedestal, this can make the problem worse. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening. If your washer is a later model, you should have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by any Do-It-Yourselfer. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Check the leveling of the washer. You need to adjust the feet of the washer ensure it is level front-to-back and side-to-side. The feet are adjusted using a wrench to turn the legs up or down. Use a level to check your work. Once completed, you should be able to place your hands diagonally across opposite corners of the washer top and see if the washer moves at all. If unlevel (just the slightest) the washer will vibrate during the spin cycle. If the washer is mounted on a pedestal, you level the feet of the pedestal, NOT the washer. Make sure the washer is firmly mounted to the pedstal fisrt. Then, level the feet of the pedestal using the same procedures outlined before.
Another cheap method to get rid of vibration is to use foam padding to sandwich between the sides of the washer, the dryer and the wall. Swimming pool noodle foam works real well and is very inexpensive. About $3 or $4.
Overloading the washer with heavy items can cause excessive vibration due to an unbalanced load. If you load items so full that you can barely close the door, the load will have a hard time distributing evenly around the perimeter of the wash tub. Once wet, and the tub begins to tumble, the load becomes entangled and will pack on one side of the tub. This will cause the washer to jump and walk across the floor on the spin cycle. This can also cause premature wear to the door bellow, damage to the door latch and damage to the shock supports and counter-weights. Always follow the manufacturer's wash load recommendations as outlined in your owner's manual.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The floors in these areas are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint, trim molding, and even tile to give it that "supposed to be there" look.
You may get mixed reviews about this, but I have seen it work for homeowners. Plus, its a less expensive option than hiring a contractor to firm up your sub-flooring or joists.
I hope you find this information informative and helpful. If you have questions, please let me know.
on Dec 13, 2009 | Washing Machines
How do I balance a Kenmore 70 series washing machine.
Wood laminate flooring is never a good idea in areas that can get wet often. But, that being said, there should be leveling feet on the washer which should allow you to get it stable on the floor, if that's what your problem is. If your problem is that the washer tends to walk around the room when in the spin cycle, well that is partially due to the fact that washers often vibrate when they spin, especially when spinning large, bulky objects like quilts and comforters, that the feet on the bottom of washer are smooth plastic, and that smooth plastic feet don't stay in one place to well on wood laminate floors.
Mar 04, 2015 | Kenmore Washing Machines
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Our Kenmore Elite front loader vibrates when it kicks into the high spin cycle. What should we do about this?
if located in upper floor laundry room,you may need to compensate a weak floor by putting an absorption pad under all four legs of the washer...if the dryer next to the washer vibrates when washer is spinning,the floor is the problem,not the washer
Mar 06, 2010 | Washing Machines
Washing machine vibrates bad in spin cycle
dont put full load please check it with half load or add water excess
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Vibrating with or without clothes as if out of balance
Vibrating or rocking? try pushing the drum around manually in the washer front back right left.re check level.
Jan 23, 2009 | Maytag Performa PAV2200
Excessive vibrations
I have ordered KE shake away pads. I'll have to see how they work.
Jul 01, 2008 | GE Washing Machines
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
Maytag Atlantis MAV9750A Top Load Washer Logo
1,159 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
