Question about Uniden Cordless Phone
Tesco ARC200 Cordless DECT Phone
I have a tesco ARC200 Cordless DECT Phone and the handset says unregisterd and i cant find the manual or remember the pin code to unlock it! is there a way to reset the phone? i have already tried the method mentioned on the youre page and this was unsuccessfull. thanks.
  • Anonymous Dec 13, 2008
    Can't register my phone. no manual!!!! No ring tone avail.
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Posted on Dec 11, 2009
Hello! I have the same problme like this: "i have a tesco ARC200 Cordless DECT Phone and the handset says unregisterd and i cant find the manual or remember the pin code to unlock it! is there a way to reset the phone?"
Thank you for helping
Posted on Feb 15, 2009
Take it back, I have one and I can't use it, I have the earpiece speaker up to maximum volume and can't hear a thing......and no, I'm not hard of hearing, believe me, it won't be worth the bother finding a manual. Mine is going back to the store today!
Posted on Jan 26, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
consultel1
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
I forgot my security code for my uniden dect 6.0 . I reset the default code when I got the machine six or seven years ago. how do i reset or retrieve my code ?
For the Uniden DECT 6.0 6035 system...
Setting a Security Code or Personal Identi?cation Number (PIN)
To play your messages from a remote location, you will need to enter a two-digit security code or Personal Identi?cation Number (PIN). The default security code is 80. To change the PIN:
1) On the handset, press [Menu/Select]. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
2) Use the number keypad ([0] through [9]) to enter a two-digit security code (00-99).
3) Press [Menu/Select]. You will hear a con?rmation tone.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
Unlock cordless phone
Since you didn't give the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl to download a copy of the manual.
Apr 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
I cant turn on my ringer on uniden cordless phone tryed to and cant get to adjust the ringer any ideas
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest that you select it from the list beginning here to download a copy of the manual.
Apr 30, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Instruction booklet
Find the company that makes it and go online. The company is usually happy to let you download the instruction manual or they will send it to you as well.
Sep 14, 2009 | Uniden Cordless Phone
Tesco ARC200 Cordless DECT Phone: Batteries will not charge.
A new battery is available from
www.espspecialbatteries.co.uk
Jun 02, 2009 | Uniden Cordless Phone
I have a Tesco Cordless DECT phone model ARC201. Both handsets have come up with range out. I have switched off the phones, unplugged from wall etc. and then reconnected - and they remain the same. I've...
Maybe a little bit late, this is the solution for registering the handsets: hold the button on the base until it starts beeping, then, on the handset, go to the Register menu, select base number - in my case it's 2, then it will ask the PIN - the default is 0000, and that's it.
Jul 12, 2008 | Lands Phones
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Handset says unregistered
The manual says that to register it needs to be completely powered off and then restarted. I unplugged my battery and then plugged it bacdk up.
Feb 28, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
1,595 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
