Question about GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
My ge ff16d uwright freezer 15.7 cu. ft.
Run never shut off aut defrost and temp good , said should run 30 min. and shut off, but it don't.
limoal@ bellsouth.net
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
nnesmith
  • 162 Answers
SOURCE: Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Posted on Jul 26, 2009
heatman101
  • 43501 Answers
SOURCE: Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
heatman101
  • 43501 Answers
SOURCE: freezer cools to 48 degrees
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
heatman101
Posted on Jun 01, 2010
AdiIngel
  • 87 Answers
SOURCE: we have a general electric 20 cu ft chest freezer.
Yes, the freezer / refrigerator is a heat pump, it transfers heat from the inside to the outside. Heat transfer effitiance is reduced if the outside is at hight temperature, so it is sudgested to allow free air flow for the back of the cooling device (where the radiator is )
Posted on Aug 05, 2010
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
20 cu. ft. / 566 liter Commercial Freezer J1GF-20S: We are trying to use this product to keep ice crea...
if it freezes you and get a new defrost timer with a wire on it and it will have diff times on it
May 06, 2010 | Coldtech 20 cu. ft. / 566 liter Commercial...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer Temp keeps getting too high
heatman101
Dec 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Defrost mode
typical defrost set up 8 times a day (24hrs)
duration about 20mins for the size you have described.
defrost stop temp should be 20 C
recovery time about 10 mins
so pls consult manuals and rest parameters.
Feb 23, 2008 | Hoshizaki 18.8 cu. ft. Commercial Freezer...
Won't maintain a constant temp. Varies from +10 to -15
i doubt that.def sounds like bad cold control though,good news if your producing cold. Hair dryer good---- Ice Pick no good!!!
Feb 18, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH Logo
148 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
