Question about Whirlwind FH-778 Air Conditioner
Residential AC Carrier
How do I recover the freon to the condensor and store it there while I disconnect the indoor air handler and clean it?
  • Whirlwind Master
  • 903 Answers
If you have never done this before or have limited experience, let a qualified tech do it for you. It's worth the money and safety. If you have a set of gages and some experience, let me know and we can contunue. It's not too hard but some what dangerous. Think about it.
Posted on Feb 21, 2009
Why does my A/C condenser compressor turn on and off every 5 minutes?
You need good airflow across the indoor coil, the evaporator. Air warms the refrigerant. If there is no airflow, the refrigerant will come back out freezing cold (in liquid form) and can damage the compressor valves. Before charging any ac unit, good airflow must be checked for across both evaporator and condensor.
Too much, overcharging will cause freezing all the way back to the compressor in a capilary tube type of ac.
Where is it the refrigeration lines are freezing cold?
Apr 28, 2015 | Heating & Cooling
Why is my A/C condenser compressor overheating, causing compressor to turn on and off every 4 minutes?
THERMOSTATE SIGNAL SHOWING OVER HEATING AND NOT RUNNING NORMAL ,HENCE OVER HEATING TRY CLEANING MAY HAVE DUST OR IT COULD BE THERASTSATE TO CONTROL AIR TO COOL
Apr 27, 2015 | Heating & Cooling
I have a carrier air handler heatpump can I use a Rudd heatpump condensor
Yes if they match up correctly. I would stay away from Ruud though. Best off with Carrier or Trane in my opinion. Also, if your spending the money to replace the condenser, you should spend the extra bit and replace the air handler as well. New systems use a new refrigerant that is more cost effective and better for the environment.
Jan 26, 2014 | Heating & Cooling
Air conditioning wont turn of, error code at furnace appears to be 24 - secondary fuse open?
There is a 3 or 5 amp fuse on the control board inside the air handler.
Disconnect power to the air handler,locate the fuse and replace it with a good fuse.
The fuse is the same type used in automobiles.
You can purchase them at a auto parts store.
After replacing and turning on the power there will be a 5 minute delay before the board and thermostat energize.
After 5 minutes set the thermostat for you heat or ac function.
If the new fuse blows a complete diagnostic must be done to the system.
Apr 24, 2011 | Carrier Heating & Cooling
Goodman Condensor cplj48-1 Air handler Modle
It sounds undercharged (needs more refrigerant). Based on the conditions in your post and assuming the indoor humidity is within 20-70% range, your target superheat should be 10degF. Your superheat (assuming you have an R22 system) is far too high. The pressures are not indicating a restriction; therefore, I have to conclude you have a low charge. A low charge will cause a gurgling sound due to the refrigerant in the liquid line is vaporizing prior to reaching the Cap tube at the Air Handler.
I hope you find this information helpful to you moving forward. :-)
May 10, 2010 | Heating & Cooling
We wired a split system ac unit. after a year the ac contractor said we had a wire between the outdoor unit and the indoor unit reversed and it ran all the time. could that have happened? could that haved...
It's possible. On the air handler the red post on the circuit board always has voltage and should go to the thermostat. If for some reason it was hooked to one of the wires to the condensor it would have ran all the time.
Sep 23, 2009 | Heating & Cooling
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Jul 12, 2009 | Coleman Heating & Cooling
Air Handler's Coil is dirty. How do I take it out to clean?
theres only 13 oz.s in it you'll have to recover it with a redclaim machine
Apr 21, 2009 | Coleman Mach 15 Air Conditioner
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
