Question about Acer AL1717 17" LCD Monitor
ACER AL1917W AND AL2216W both LCD's
Both monitors are less than a year old. The first the 22" was bought in Dec 08.
After 3-4 months it developed a problem. You turn on the monitor and it would only stay on for a few seconds and go off, and developed a loud hum. You simply could not keep it turned on. No matter what display or settings you tried. So than bought the 19" and now it developed the same problems.
The monitors do the same thing on different computers. So it is not the computer or power to them. I also have a 22" Samsung LCD and 15" gateway LCD and all work fine.
Any thoughts.
Bammbammfran, do you repair these through ebay or sell the parts. whats the price either way?
Posted on Nov 08, 2008
  • 159 Answers
What do the power button lights do when there is a signal to the monitor and when it has a signal taken away from it ??
I believe your power boards have failed capacitors and need to be updated. Seems they used some crappy ones in some of these models.
I fix quite a few through ebay and that is a common problem, sorry to say.
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor.
HERMAN has the correct response. For the info you posted.
When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Aug 07, 2012 | Acer AL1917W LCD Monitor
Does the ACER AL1917W have web cam capabilities?
ACER AL1917W is a fine monitor but it doesnt have Web Cam.
You can buy a Web Cam separately and connect it to your computer.
Feb 11, 2011 | Acer AL1917W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual;
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
I have same problem
Replace the following capacitors:
3 pcs - 220 microF - 25v
2 pcs - 1000 microF - 25v
1 pc - 2200 microF - 25v
Resolder the 2 transformer legs for the inverter.
Triangle Tech Whiz.
Jul 23, 2009 | Acer AL2216W LCD Monitor
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Acer AL2216Wbd blurry
get it checked that a problem with the monitor also check it on another monitor if you can
Nov 20, 2017 | Acer 19" LCD Monitor
Ghosting of the image
no it is a board replacement at best, so i would look into replacing the vga board or getting a new monitor and selling the damaged one for parts with the issue listed
May 11, 2008 | Acer AL2216W LCD Monitor
Acer AL1717 17" LCD Monitor Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
