Question about Astatic 636L Noise Canceling Microphone Microphone
I have 2 Electro Voice Microphones that need worked on. The model number is: RVC 4:179.100 RVC 1:174.100 They are pretty old. Around 9 years old. Is there anyone who works on these? I would like to have them as backup mics. Steve
It won't work. other microphones will work in the same cord.
it could be either of the following
a) open voice coil ( no resistance, with a multi meter check)
b) voice coil is good but not the wiring .
Sep 24, 2012 | AKG D880 Professional Microphone
The sleeve on my nd257b has dropped to bits after 10 years will a replacement hand sleeve from one of the current models fit it?
I called Electro Voice and they told me they are available and cost $7.00 plus shipping. Problem with direct order from them was $25.00 minimum order, so now I've got to find a dealer to order one from. The part number they gave me was....F01U110242. Good luck. I'm going to check with the Sam Ash in Orlando FL and see if they can order one for me through their distributor
Aug 11, 2010 | ElectroVoice ND267A Professional...
Just stopped working..
check control panel for audio setting to make sure it is enabled and recognized
Feb 26, 2010 | Dynex Voice-Certified PC Desktop...
Voice coil open circuit - replace?
The diaphramgm price is $224.00 to do it yourself with no warranty. If you send it in to be repaired it's $200.00 with warranty. Telex Communications handles all Electro-Voice repairs In Lincoln, Nebraska @ 1 800 553 5992 ask for RE-20 diaphragm repair info.
May 04, 2009 | ElectroVoice RE20 Professional Microphone
My congregation has a four year old sound system
here is a contact number for the manufacture. 1-800-392-3497
ask for electro voice parts
tell them the model number and make
and a description of the part you need.
Feb 25, 2009 | ElectroVoice Electro Voice HTU2D-767A...
When I make or receive calls, nobody can hear me.
yes you can fix it.. open the phones and swap the microphones, thats it.. hust make sure that it has same size..tnx
Feb 06, 2009 | Nokia 6133 Cellular Phone
Both my EV RE20 Mics have somrthing loose in them
Here's a schematic that displays the assembly of your mics. You should only need a hex tool, jewelers screwdriver, and some patience.
Dec 12, 2008 | ElectroVoice Electro Voice PolarChoice...
Logitech Clear Chat Stereo microphones
You should go to logitecs website and search for the microphone drivers and install them. Thhis should solve your problem.
Kenneth Triest
Oct 23, 2008 | Shure Head Set Microphone Microphone
Astatic 636L Noise Canceling Microphone Microphone Logo
46 people viewed this question
Top Astatic Audio Players & Recorders Experts
Michial Gueffroy
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
