Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA dlp - Shadow
Did you ever figure out how to fix your shadow problem. I have the same issue.
    Problem Solver:
  • 5 Answers
It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
Posted on Mar 22, 2010
A shadow on the picture
The shadow could be caused by a dust partical that is trapped. You could try to dislodge it with an air duster or a vacuum with a soft brissel attachment
Feb 07, 2014 | BenQ W100 DLP Projector
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Rca model# hd61lpw163
hi,
while having another problem fixed the tech told us about fixing the shadow in the corner problem. check the tubes. he said when they get hot the glue around the tube melts and causes the problem. he removed the access glue and ours is all better, i hope this works for you too.
Jul 11, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
I have an rca 61" dlp hdtv. It is about 5 years old. I have a shadow over part of the picture and it has suddenly lost most of its brightness.
In terms of figuring out what was causing the problem, I have answered that question. I disassembled the light engine and found that I have a burned plastic optic lens in a part I believe is called the "light gate". Now the challenge is to find a place where I can get one since you apparently cannot get it from RCA. I certainly would never buy another TV from RCA or Thompson.
Jul 09, 2008 | Televison & Video
Dlp tv
No, don't wait. Make sure you get RCA to cover this under warranty. Don't wait for everyone with this model to have the same problem and jam up RCA with the customer service nightmare that is rampant in this industry.
Dec 07, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
257 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
