I have a Aspire 360 notebook and it will not boot its says exiting PXE ROM Operating system not found no boot filename recieved i only had this notebook 1 year help i home school so its is very important for me and my children
    Guru:
  • 1,342 Answers
Click Here to read the solution given to another asker with the same problem.
Posted on Nov 08, 2008
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
Keep getting the following message when I turn on my Acer Aspire 5050 laptop: PXE-E61: Media test faulire, check cable PXE-M0F: Exiting PXE ROM Operating System not found
PXE bootup means the computer does not boot up from an operating system installed on a hard disk drive. PXE bootup uses a server on a network to boot up the computer.
It will not start without being connected the network that it was programmed to run on
Nov 16, 2009 | Acer Aspire 5050-3242 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Pxe e53 no boot filename recieved,
check your harddisk is detected or not in bios setup
Apr 05, 2009 | Gateway Computers & Internet
Booting problems with acer laptop - no operating system found??
well ur msg clearly states operating system not found.
for this u hav to install ur OS again.
As ur sister has a branded machine u must hav got a Operating System CD-ROM with it for backup.(in ur case it must be vista)
if u hav the cdrom then turn ur system on just put the cdrom into the drive and let it do what follows.
It may ask u abt where to install ur OS(means which partition)
just select the desired partition and many other simple questions which u can easily answer incase u hav any problem I am always there.
Hitesh
+919923888524
Jul 08, 2008 | Acer Aspire 5050-3242 Notebook
Acer aspire 5630 wont boot up
it may be that the harddrive had broked, or is not properly mounted. Try removing it and then reatach it. what operating sistem do u use ?!
also try booting with a linux live cd and see if it can accesc the hard drive, if it cant, than thatşs u're problem. If it can, than u have to find out what PXE-E61 is (what component), and then test it (i presume is the hard drive or the optical unit)
May 01, 2008 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
