Sony tv Hello mistrsony I hope this is how I get a hold of you, this site is new to me. I have heard that it could be the thermal fuse and I also heard it now comes in a kit for around $45.00 is it easy to install, I 've heard its some where by the lamp. Steve
  • steveb515 Nov 09, 2008
    hello mistersony
    sorry it took awhile to get to you, fighting some kind of bug.
    my email is steveb515@yahoo,com
    thanks
  • 320 Answers
I need an email address to send you a copy of the service bulletin on how to do this the correct way. PLEASE do it the way describes in the bulletin, and not as other have described it on the site. If you choose to do it the east way, you risk having your very own timebomb/fire hazard sitting in your living room. I'll wait for the email address and send it to you. Thanks!
Posted on Nov 08, 2008
  • Any Guy
    Any Guy Nov 09, 2008
    Steve,
    I have sent you the bulletin and step by step instructions for doing the repair. let me know if I can be of further service.
    mistersony
Sony kdsr60xbr1 standbuy blinks red 6 times. Pulled lamp out, it was broken. I heard lamp pop. Do I just need to replace lamp or is it something else as welll?
If your not sure, google name and make of tv and "red light blinks 6 times". That usually is a code for what is wrong.....My money is on the lamp....especially if it was working fine before. Hope that helps and gd luck to ya
Mar 13, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
TV turn off every 45 minutes
6 blinks = thermal sensor. in rare cases its the power board but in this case its usually a faulty thermal fuse. it sits under the lamp and can be tested with a multimeter or ohm meter. you can short it out and the tv will work but it will lose its fire safety, but this can get a temporary fix until you get a new fuse. the new sony fuse is like $15 for the part i believe. let me know how you want to procede.. repair center cost = 100-200 $ hopefully
Jan 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA 60" LCD TV Problem
TO FIND YOUR THERMAL FUSE ITS LOCATED ON TOP OF THE LAMP FAN HOUSING SHOULD BE 2 BLACK WIRES RUNNING TO IT IT'LL HAVE A LITTLE BLACK SQUARE ON THE END OF IT THATS YOUR THERMAL FUSE
Jan 06, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Kdf-55wf655
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Jun 05, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Replacing Thermal Fuse in Sony Grand Wega KDF-E55A20
The PROPER way to replace the thermal fuse is to remove the optical block first. There are at least two recessed screws holding the block in place. BE VERY CAREFUL removing the block as it is very easy to tear/rip wires when doing so. I cannot emphasize enough NOT TO JUST THROW THE NEW THERMAL FUSE INSIDE THE CABINET!!!! The thermal fuse is a safety device mounted near the lamp to prevent overheating. Those that choose to just let the fuse "sit out in the open air" are risking greater failures and the possibility of fire.
May 27, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Thermal Fuse
The thermal fuse is usually located near the lamp to prevent the lamp overhaeting and damaging the set. Sony uses two types of thermal fuses: the first type is a circular metal type, about the size of a quarter with two metal tabs for push on lugs that connect to the TV. The second type is a small plastic half moon type woth wires coming from the base. Contrary to what you might read elsewhere on this site, it is VERY IMPORTANT that you mount the new fuse where the old one was, for safety reasons.
May 21, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20
Sony model KDF55WF655 blinking light 6 red flashes,no picture,no sound....
I just replaced my thermal fuse for $4.80 plus shipping handling.Took me 30 minutes to fix and 30 minutes to get dust out of TV.Take off the back of the tv about 8 screws,then remove the fan housing on the right hand side about 4 screws.If you have the new fuse you will know which wire it is ..grey and white.I found it easy to get to the other end through the front panel of the tv only 2 screws ,remove front panel and then remove cover on projection bulb and you will see the other end of the fuse clipped on.Remember to unplug tv. TV is working excellent now .
Thanks to everyone on this website.I have pictures if anyone needs them to repair it.
Mar 01, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
Jan 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Pwer flashes 5 green 6 red
6 blinks is most likely thermal fuse failure. parts should be available through sony. thermal fuse is a 2 pin device under the lamp cartridge(looking from back) metal oblong looking peice that is screwed into the bottom of the tv. the new thermal fuse sent from sony will look completly different and as long as you cut the wires on the old one you can leave it in the tv and position the new fuse around the old one.
Dec 08, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kdf-60xs955, rear projection tv
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Jun 19, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
