Question about Toshiba 50HDX82 50" Rear Projection Television
Randomly turns off??
The sound and picture quality on the set work fine. The problem is that it seems to heat up and then just shuts off randomly. If the set is on for about 2 hours then it will just turn off. If i give it a few minutes then it works fine again. I have taken off the back service panel and the unit is free of dust and dirt. Any solutions to this problem?
  • 934 Answers
A common failure for shutdown in this unit is R428 and/or D408 in the 200v line. R428, due to heat, can change in value over time and eventually open. It may only be at that stage where the tolerance has changed but it will eventually open. D408 in that same line and for the same reasons tends to leak as it warms up allowing voltage both directions - thus shutdown. Might check thse and see if that's where your problem is...
Bill
Posted on Jan 09, 2009
Samsung dlp hl55679w
It sounds that the light engine has the fault. Contact the authorizes service center for Samsung.
Jul 21, 2013 | Televison & Video
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Jun 16, 2011 | 2002 Chevrolet Malibu
How can i tell if the fan on my vaio CS31S isnt working properly? It seems to speed up and down and the laptop shuts down? Is it te fan or could there be another reason for this shutdown? :-)
Try blowing out any dust from around the fan with compressed air. If the fan is turning on and off a lot, this could be normal, depending on your processor, but if the system just shuts down fully and randomly, it would be a heat issue. The CPU is overheating and the failsafe mechanism is to instantly shut your computer down. The only way to avoid this is to raise the CPU shutdown temp in the BIOS settings, or if you can access the CPU, remove it and apply new, quality thermal grease. Also, ensure the fan is operating correctly during use and dont block any air intake or exhaust ports.
Mar 08, 2011 | Sony CPU FAN CPU Fan
Monitor shuts off randomly!
1. This is main-board related. You either have a Micro controller or power supply issue that needs to be address by a tech. Shut down is direct relation to a circuit component in the start up that has failed.
May 01, 2010 | ASUS Eee 4G Notebook
LG Env2 randomly turns off
I had the same problem, I took it back to the Verizon store and told it was caused by heat exposure from being outside. He reset my phone and the problem stopped (until I had it outside at the pool again)
May 31, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Presario M2000 wireless turns off (light and all) randomly
Sounds like a mechanical problem with the button... are you still under warranty?
Nov 03, 2008 | Compaq Presario M2000 Notebook
Samsung pcj522r shuts off randomly
samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
May 12, 2008 | Samsung PCJ522R 52" Rear Projection...
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
Toshiba 50HDX82 50" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
