Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd63 door for some reason the door light will not go off so I cant open the door any ideas, programs have so it seems finished so every thing seems ok. is there any way to open the door with the lock still trying to lock it. paul
  • 135 Answers
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Posted on Nov 08, 2008
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Finisher door closure switch/sensor not working.
Have you tried to turn the copier OFF and unplug the finisher and turn the copier back ON with out the finisher pluged IN. If it works just don't use the finisher. I believe that model is rather old and you may have a problem finding parts for it, there are a lot of different reasons for the door not being showed closed. Good Luck
Apr 05, 2009 | Office Equipment & Supplies
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door won't open for Washer Dryer
WHAT HAS HAPPENED HERE IS THAT IS THE INTERLOCK HAS SHORTED AND BLEW THE FUSE AND THE REASON WHY THE MACHINE WORKED CAME BACK ON IS BECAUSE THE INTERLOCK HAS NOW OPENCIRCUIT AND THAT IS WHY THE DOOR WILL NOT OPEN JUST REPLACE THE INTERLOCK
Apr 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Door locked
Press 'end of cycle' button for over 3 seconds, & wait for a couple of minutes then try the door. Do not force door.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd63 washer dryer when complete when i open the door alot of hot steam comes out
your water supply to the machine has been turned off, or the triplewater valve has gone open circuit on the condensor solaniod if you have a multimeter you can test the valves unplug the machine from the mains and turn the cold water supply off , take the back panel off take 2 wires off at a time and test each solanoid they should read around 3800 ohms if you nget no reading on 1 of the solaniods thats you problem change the complete valve. good luck
Jul 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Door won't open
two possibilities water not fully drained - door won't open if so handle mechanism broken - check if it too free to move or sloppy
Feb 25, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
