I just installed this amp. I have a pioneer deh-p6600 hu. I have not touched any of the settings of the amp yet as I just finished installing it. But I have the 2 rear speakers running off of it and I also bridged the 1 and 2 channels for the sub. So right now it is wired as this. Channel 3 and 4 to rear right and left, channel 1 and 2 bridged to sub. But I only have sound from 1 side of the rear speakers. When I switch the rca cables sound comes out of the other side. I have the rca cables pluged into low level 3 and 4. Is that right? I want to use this in tri mode. 2 rears and 1 1 sub/. I am going to look into it tommorro to see if I can figure out whats wrong but your help would be much appreciated. Thanks Eric. Ps I am using the rear rca outputs from my hu.
SOURCE: Diesel car amps not working
Hello Rudnette,
With out being given much information to work with I can only give you a basic run down of what the problem might be. It sounds like the MOSFET amplifiers have blown out on those channels that are not working. Did your system become ungrounded at some point while it was playing, and or did you have some kind of power surge?
Let me know the conditions under which the problem happened and I might be able to provide a better analysis.
Thank you,
Shuttle83
SOURCE: i have a 250 watt
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Go to the link below then scroll down to product details. Then click on product manual. On page 32 it will tell you how to set the clock.
http://www.amazon.com/Pioneer-DEH-P6600-player-Full-DIN-dash/dp/B00025YP6S
