Question about Sony Playstation 3 (PS3) Console
How to connect my usb modem to the ps3
I have a usb modem i connected it to my computer then bought a lan cable to connect my ps3 to my computer but when i run the connection test on my ps3 it tells me that the attempt to optain the ip address timed out because of a dns error
how do i solve this problem plz help
p.s.there is no dns server on my computer cause i use a usb modem
  • 1 more comment
  • Anonymous Feb 02, 2009
    I have the same problem. I bought a wireless router to connect with my ps3 but I couldn't because it kept saying the ip address was not found or was timed out. Sometimes though it would work but for 5 minutes or an hour but then the internet on my computer wouldn't work. Are there any wireless routers specificly desined for usb modems or should they all work?
  • Anonymous Feb 22, 2009
    i keeps sayin my ip address has timed out i have a 3 usb modem (dongle) can any1 help?
  • nattieboy1 Mar 14, 2009
    i have a mf622 USB modem (3) which is plugged into the computer i then bought an ethernet cable which ran from the ps3 to the laptop. It says ip address failed. Does this mean i need a router?
  • 1,879 Answers
Recommendation:
Get a Modem and a Router in order for both computer and PS3 to be online at the same time.
PS3 assumes that it is connected to a router/gateway and is not designed to have a modem directly connected to it as would need additional hardware/chips incorporated.
Posted on Nov 08, 2008
I just bought a PS3 and it basically does not allow me to connect to the internet. When I go into the menu it keeps loading forever, I waited like one hour and nothing happened. I can reboot it and the...
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
How to get it online with a ps3? I hooked it up to the ps3 with the Ethernet cable. It says connection failed .but it wont go online. Any help would be dearly needed. Thanks
First test the Internet connection by connecting a LAN cable from your DSL or cable modem to your computer and see if you can get into the Internet.
If you can't access the Internet then phone your ISP and get them to test your connection to your modem.
If the Internet connection is OK then click on this WEB site and follow the instruction to configure the PS3 :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Jan 01, 2010 | Arris SURFboard SB5101 Cable Modem
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Bought a new laptop; want to connect it to this modem via wireless
is your pcx1100u cable modem is not wireless ready? only router have a wireless lan... buy it...
Jun 16, 2009 | Toshiba PCX1100U High Speed Cable Modem
How to hook Cricket USB Broadband Modem to my PS3
is it possible to connect my ps3 to the internet using cricket broadband modem?
May 03, 2009 | Sony Playstation 3 (PS3) Console
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Printer and Modem
are you using a USB cable to connect your modem ? Are you using a USB cable to connect your printer ? If you are using a USB cable to connect your modem, try using an ethernet cable and your LAN card instead. It will work better and you won't need modem drivers to make it work. You do however have to have a LAN card or built-in LAN adapter. As long as you have one of those 2, the best way to hook up your modem would be by using the ethernet jack on the modem straight into your LAN card/adapter. If you are not using USB to connect your modem then please send me your printer model and how it's hooked up and I will help you figure it out. Hope this helps.
Sep 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Sony Playstation 3 (PS3) Console Logo
417 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
