Question about Bernina Virtuosa 160
Threading the bobbin
I just can't get it to work correctly! Everytime I try to thread the bobbin and sew it gets all bunched up. What I am I doing wrong?
Thanks,
Rachel
It could also be the tension of the thread while you are threading the needle through the upper system. Keep a slight tension on that thread while doing it. Otherwise, make sure that the bobbin thread is 'coming' from the right position on the spindle.
Posted on Nov 15, 2008
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Brother pe180d thread bunching up underneath
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Dec 02, 2012 | Brother Disney PE-180D Computerized Sewing...
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
The bobbin thread keeps bunching up on my 990 machine
It is probably not the bobbin thread that is "bunching", put different color top (maybe red), and bobbin (maybe white), thread in the machine and sew. If the top thread is messing up on the bottom of the cloth you have 3 possible solutions. Here are the solutions in order of probability:
1 - You have not threaded the UPPER thread correctly. Read your book on threading.
2 - Your UPPER thread tension is too low. Try setting it at 5 or so.
3 - Your shuttle is damaged. Get a new one.
Jan 15, 2011 | Husqvarna Sewing Machines
When I sew a few inches, bunches of threads come out of the bobbin case. It's like it gets clogged or something. I'm getting nowhere with this. Help!
If your bobbin is the correct one for your machine and it is wound tight, not loose and puffy, make sure the thread is going the right way when installed (over the top to the left and then placed flat in the bobbin case). Usually if the thread bunches underneath your fabric it means that the TOP thread is threaded incorrectly. Try re-threading the upper thread. Good luck!
Aug 21, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Bobbin thread bunching
rethread top carefully, you're not getting it in the tension
Jun 17, 2009 | Singer 3116 Simple
Sewing Machines Logo
83 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
