Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Ghosting - colored shadows - guns out of alignment?
This TV is several years old. It has a lot of ghosting. the right side of most images is green, small graphics are nearly impossible to read
  • Panasonic Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneerghosting - colored shadows - guns out of alignment - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
I have a Sony Grand Vega 60'' XBR800 and it has been working perfectly with HDTV hookup and DVD direct input. Lately, I have noticed some ''green halo'' on the images on the left side of the screen. I...
Hi, It sounds like your lcd chip has gone bad this is how your technology works ;http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 lcd chips that create the image and colors by blending together.When they start to go bad you will get color distortion, color halo,spots even lines.You will need to replace the light engine.I suggested to contact you manufacturer to see if they can fix it at no charge since this is a common problem and even where in a law suit because of that problem.
Mar 03, 2010 | Televison & Video
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
Have SONY KP-46WT510 (NOT SURE OF MODEL NUMBER RIGHT NOW) 46 inch rear projection tv/silver with matching stand. Picture Color is shadowing/ghost images in pink and green. Cable dvr box said 8888. Had...
STK ICs replace Both of them they are big black ICs will have part number on them also CK pico fuses in frnt and back of ICs they look like resistors but will be green or yellow Call Mats 1-800-628-1118 cost of Parts $20.00
Dec 08, 2009 | Televison & Video
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
