Question about Omron C28FL Nebulizer Air Filters
Omron hand held nebulizer will not go on no light or activity
Will not go on even though plugged in when switch is pushed it will not stay on.
Check the connectors.Mine are corroded.I do not know how to clean them or if I can. Same problems as those I read about. Any one know what to do ?
Posted on Jun 22, 2013
  • 74 Answers
This link will let troubleshoot with Ormon....I hope this helps.
http://www.omronhealthcare.com/contact/contact.asp
Posted on Jan 07, 2009
Lost adapter for nebulizer, can you use any AC adapter that uses the same output neeeded?
Hi...I just looked on Ebay and there are some AC and DC chargers for your nebulizer on there.
Dec 13, 2012 | Omron Healthcare Inc Omron AC Adapter for...
Omron vibrating mesh nebulizer quit working
You must be having trouble with the battery. Also please keep the nebulizer properly cleaned as instructed on the pack. Check the connection properly or replace the batteries if needed. Also check out for more information about Omron Nebulizer on the web. It would help you a lot.
Aug 06, 2012 | Omron Health & Beauty
My ne u22v is not making mist
You should check if the battery is working fine. I don;t think Omron U2 nebulizer can have any other problem as it works really good for me. Also it is important to clean the Nebulizer properly and please check out the manual for more info. which you would have received while purchasing the Nebulizer.
Aug 06, 2012 | Omron Ne U22V Microair Vibrating Mesh...
Reconstruction of nebulizer
I don't think there's C-08, Here's a manual for C-28 Nebulizer. This might help you a bit. http://www.omronhealthcare.com/wp-content/uploads/ne-c28_im1.pdf
Jul 10, 2012 | Omron Compair Compressor Nebulizer System...
Just clean.The light is on and will not put out any mist.
the mist will dry up.. it will appear because its nebulizer..
Apr 27, 2011 | Omron Ne U22V Microair Vibrating Mesh...
The baffle part of our Omron Nebulizer is broken could you please tell if we can get the same from somewhere in market or if the complete Nebulizer kit is available??
You can use pretty much any nebulizer kit (try the brand salter, item#8900), this is a universal kit and fits most nebs, I have not seen Omron offer the baffle piece seperate of a new kit (or new neb). Your local pharmacy (Walgreens in my area) sells the kits, or check with the provider that gave you the unit.
Jan 24, 2011 | Omron Health & Beauty
Vapour does not come out of Omron NEC28 nebulizer
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Apr 19, 2009 | Health & Beauty
Omron nebulizer will not mist. All tubing is intact. What to do?
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Omron C28FL Nebulizer Air Filters  Logo
219 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
