Http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
To replace a turntable drive belt.
Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Styluscity can supply replacement drive belts for all model turntables.
