Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire ES400 oven controls
I can't get the one of the heating elements on the rangetop to shut off.
(Electric Frigidaire range w/glass cooktop)
  • mbernich May 14, 2009
    Sorry I am a homeowner, I have the same issue with the Frigidaire ES400. I guess I need some explaniation on what "Get a new one means" What part specifically?
    Thanks in advance
  • katyess May 19, 2009
    My ES400 is 6 years old and this same problem has now happened TWICE! This part that needs replacing is not cheap. We were comped for the part the first time because the range was only 2 years old and we made a fuss, but it just happened again last night. I can't believe there isn't some sort of recall for this.
  • 833 Answers
Contacts are fused.  Get a new one, cut the power and replace it.
Posted on Nov 12, 2008
You should check with Frigidaire - there was a free update done as a recall for all ovens with certain serial numbers. Our update was installed by a repairman who came around after we got a letter from Frigidaire about a possible problem of elements staying on (or something like that - we never had the problem). Check your model and serial numbers and give them a call.
Posted on Feb 04, 2011
Hello, my range is 6 years old, I have had trouble with it 3 or 4 times, today the buner on the right hand side is stuck on.. it is unpluged now, I tryed pluging it back in, and it is still stuck on high... Please help me??
Posted on Aug 31, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
I have a Frigidaire electric oven and flat cooktop that went out. Neither the oven nor the cook top elements heat up. If I turn the element dial slightly, the digital clock lights up (flashes), but...
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | Frigidaire Ovens
Kenmore electric range with ceramic cooktop, model # 79046593500. None of the elements or the oven will heat up. The controls work, the red indicator light goes on, but no heat.
It sounds like your Frigidaire made kenmore may have a power supply issue, the power block that is located at the rear of the oven may be at fault. part number 5303935061. However the digital clock can also cause this problem, and should be diagnosed by a technician.
Mar 14, 2010 | Ovens
Stove top working, oven is not
you need to check the heating elements and make sure you have continuity if you do then replace the control board
Jan 29, 2010 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
946 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
