Laptop fell from 3 foot high shelf. Display is barely visible now, can see it but only if direct light is shone at an angle.
  • tokitoki Dec 08, 2008
    my problem is i see a line in my screen everything else work ok
    President:
  • 1,314 Answers
It sounds like you broke the backlight in the display. You will need to replace the LCD screen.
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
Hi, my display is barely visible and is on the
You may clean the display from dust from inside the receiver. Or replace the display if not suffering from solder cracks.
Oct 29, 2013 | Sony STR-DE598 Receiver
Toshiba laptop screen very dim. Icons on desktop visible at angle. model Toshiba Equium L10-300
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 13, 2011 | Computers & Internet
Cant read the menu. Is backlight broken.? I can see the word garnin when I turn power on. But the menu is difficult to read- Is it konfigutation for dark or light screen?
It depends on the model - but CCFL tubes are used by Garmin to light the screen of GPS devices. A CCFL tube comes with a high voltage inverter to power the tube. Meaning either the CCFL Tube or the Inverter can be dead.
Symptom is a barely readable screen and becomes a bit more visible when looked at from an angle. No light comes from the screen at all.
The inverter can be tested by holding oscilloscope leads close to the screen. A sinus waveform of about 50 - 60 Khz should be visible when the device is powered at full screen intensity.
Jul 10, 2011 | GPS
The screen on my toshiba satellite a135-s2386 has a red hue for the second that it remains on during start up. It will display fine on an external monitor. If an external monitor is not connected, and you...
This sounds like a problem with the back light. The back light is generally a small cool fluorescent light. The problem could be with either the fluorescent light or the inverter board that supplies the voltage to run the lamp. If you are able to disassemble it yourself you can usually buy an inverter and lamp online. This requires a good amount of dis-assembly and expertise but costs less. At a higher price but less expertise is a complete lcd display including frame and covers. This basically just requires removal of the top cover of the laptop to access the screws that hold the display on and access to the cables.
Best of luck, Jim
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
Mamiya 645 ADF viewfinder/meter issues...
You likely have a defective display module, probably with a dead back-light. Try putting a newly charged battery in it, but if the problem persists, you'll need to send it in for service.
Aug 04, 2017 | Mamiya 645AF Medium Format Camera
My hp pavilion ze5270 notebook works fine except the screen does not lightup so i can see my displayed pages. if i shine a light directly into the screen i can see the page displayed on the screen or i...
well as i see from your problem explanation i believe that the LED which are at the backside of your LCD screen is not working so its better to troubleshoot from that angle.
good luck
Jan 05, 2010 | Computers & Internet
HP Pavilion dv5003cl won't turn on after small fan falls on it.
If the fan fell directly on top of it then it could have destroyed your lcd display. Power down the laptop completely, plug external monitor into vga port on laptop, power on laptop. If you have video on the monitor then you would likely need to replace the screen. If you send it in to get fixed it will cost a lot of money. You could do it yourself if you are comfortable with that type of thing.
Sep 15, 2009 | HP Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
