Paragon 2000r gas fire - not coming on. pilot light is coming on with remote control but then goes out without activating or lighting the fire.
I have the same problem occasionally with a Paragon 2000R. It seems to be related to the thermocouple. The pilot flame does not heat the thermocouple enough. Usually re-arranging the the artificial coal to reflect some of the heat back to the thermocouple will just make the difference. Maybe it is time for a new thermocouple.
RB
Posted on Sep 27, 2011
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
The pilot light comes on when control depressed but when it is released so it can be turned to a gas control it goes out. If the fire is lit successfully, it then goes out after approx 10 mins
if pilot is blue and torch like then the thermocouple is bad. if pilot is layz and yellow then it needs to be cleaned.remove pilot gas tube and clear orifice,looks like small thimble. reassemble and check tightness with soapy water when gas is flowing
Jan 04, 2011 | Heating & Cooling
No flow of gas to fire after pilot light is lit and turned on.
i have had a legend vantage slide control gas fire for about 5 years.this problem is i believe a blocked oxy get which is a failsafe device to prevent a gas leak.can be remedied easily by a gas safe engineer.
Jan 07, 2010 | Vantage Televison & Video
Robinson wiley gas fire operation instructions
not sure without seeing the unit , but if you are following proper lighting instructions and the pilot wont stay lit either the saftey valve isnt working or you dont have enough gas pressure if the unit has a themocouple then you may be able to replace the thermocouple. let me know
Dec 17, 2009 | Kitchen Ranges
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
629 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
