I have a problem with my Canon Optura 20: When I am outdoors or in bright light area, the LCD or the viewfinder do not display the scene at all -- they remain just plain white. If I move to indoors, the scene in indoors is visible (if it is not bright). During night, the scenes are quite visible either indoors or outdoors. I tinkered with various settings but to no avail. Did anyone face this problem and if you know the answer please let me know. Thanks in advance. Chris
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the viewfinder to the camera body and will require disassembling the camera and viewfinder assembly to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
I have the same problem. I found that if I removed the battery for a while (20 mins) and then put it back on, charged it fully and then tried to use it, it would work, but if I shut the camera off and turned it back on, the problem would return.
This made spontaneous video impossible.
The 3 minute warm up is a good solution, but I would really like to turn on my camera and have it be ready to go.
