Samsung ht-tz212 protect!
I have the same proplem as you with my dvd player. The display shows protect and turns off. Do you know what the problem is?
  • 6 more comments
  • adobi Dec 17, 2008
    Same problem. It turns on after few times, but the sound for all functions is very low
  • Anonymous Jan 14, 2009
    ht-tz212 it shows protect and turns off
  • Anonymous Jan 21, 2009
    also on the samsung z-210r
    bad bad bad ...
    no solution????!!!!!
  • methai Jan 24, 2009
    Same problem. Seems that the fan is not working. Probably an overheat or blown capacitor. When it died originally, the sound faded out gracefully, indicative of that kind of problem (capacitor).
  • ams006 Mar 01, 2009
    Similar problem on the HT-X20. No fading of sound but message of 'Protection' appears and it switches off, then red stand by light flashes!..
    Any solutions as of yet??
  • hakkibasri Mar 03, 2009
  • J008 May 25, 2009
    THERE IS A LITTLE RESISTOR IN MINE ON POWER BOARD CALLED SMR 60 LOOKS BLOWN WHERE DO YOU FIND A WIRING DIAGRAM FOR THIS MODEL PLEASE
  • holbrook_chr
    holbrook_chr Jan 19, 2012
    My dvd player for the HT-TZ215R/XEU home cinema system will not start up and displays 'protect' before turning itself off again. After unscrewing the box (its way out of warranty anyway!) it looks like a resistor has blown. A RM03. Should I try and solder a new one back in place? And why do I keep getting bad electric shocks from the circuit board it's attached to when its not plugged in and seperate to rest of the dvd player?
Resistor smr60 is 470r / 470 ohm
Posted on Jul 19, 2010
  • 3 Answers
The circuit diagram would not help you as it is missing on it. However I have found someone who knows.
It is a 470ohm 1/4w
Posted on Jan 25, 2010
I have the same problem with my Samsung TZ215.
The resistor SMR60 is blown. Can anyone provide me with details on what this resistor was? Even just the colours so I can solder a new one back in. If this works it may be a solution that can save many people time and money.
Dan
Posted on Oct 12, 2009
  • Noel McCabe Jan 10, 2011
    The colour code is: Yellow Violet Brown Gold
    Noel
Ik have this problem to, i am from holland en bought the home cinema set hT-Tz222, is sad PROTECt one time, and since then it is working but the sound is not oke...
Posted on Jul 24, 2010
"ht-tz212 protect"
noted RM03 blown in PSU
replaced RM03 (1/4W flameproof 10 Ohm)
SMD03 shorted (replaced with RGP15J)
seems to be ok
Posted on Feb 25, 2011
Why when we whatch movie the system off in few minutes?
Samsung Home Theater HT-X40 - Shut Down on Protection ...
craftsman-hambs.blogspot.com/.../samsung-home-theater-ht-x40-shut-do...
Sep 5, 2009 - Samsung Home Theater HT-X40 - Shut Down on Protection Problem ....My system even sounds a little better now but that could be because I ...
I have a Samsung HT X40 DVD Home Theater. The problem ...
www.justanswer.com > Consumer Electronics
Question - I have a Samsung HT X40 DVD Home Theater. The problem ... Turn off the power and hold the STOP [] button for longer than 5 seconds. This reset all ...
Samsung Home Theater System HT-X70 "Protection ...
www.manualsonline.com/.../samsung/...system/protection-problem-shut-...
Jan 01, 2016 | Samsung HT-X40 System
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
My Samsung HT-DM550 shows "lock"
Be careful to do this with AC cable disconnected from AC outlet! If you have some experience with electronics, disconnect the wired plugs from power supply and discharge electrolitic capacitors to ground with a 330 ohm 1 watt resistor. Then reconnect the wired plugs. Be careful to do this with AC cable disconnected from AC outlet! Then connect to AC outlet and turn on the DVD player. You will see that DVD player restores to normal operation again.
dady_happy@hotmail.com
Oct 29, 2010 | Samsung HT-DM550 System
Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Mar 14, 2010 | Samsung HT-Z210 Theater System
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
3,843 people viewed this question
 Grubhead
Grubhead
