Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding mower floods after a few seconds
Briggs & Stratton 19 HP model 42E707 type 2631 E1
The choke mechanism seems to open and close properly. There was gas in the oil. I removed the carb, disassembled it and sooked it in carb cleaner over night. Blew out with compressed air the next day. reassembled using new carb and pump repair kit. New plugs, new filter, replaced oil and it starts right up but floods out. I made sure the choke was off. The filter is dripping with gas and if I let it sit a while it will do the exact same thing.
FYI...just thought I'd give a little back...
had exactly the same mower/plow w/ same issue !
mine is an older L-head from pre-1998...used....
19.5hp 3 screw type diaphram fuel pump carb...
the pic's and how to assemble... I will send if,
you email me... Instructions do not come from
B&S when you buy there part # 694056... = 10$
carb rebuild kit...they want to sell the manual too !!!
sku# 0 24847 26246 9 ...shame on them !
they are selling manual # 27xxxx for 20$...
to tell you what to do ! ....%$#-THEM !!!
I made a pdf...with before and after pic's of
how to rebuild this carb...it's quite unique in fuel pump design and simplified governor operation...
running well this 19.5 twin - fan cooled...is like a 25HP !
the carb kit from B&S is generic...w/extra parts...
I have pic's of the actual ones used/needed for this
carb... Main jet is mis-labeled...it's a bowl vent !
There are no jet's to adjust on this carb...
only adjust is idle speed post the governor linkage !
also shown functioning in my .pdf...
hit my mail ..... driscoll_at_pzdi_"dot"_com
or visit www _ pzdi _ com
248-390-3541
Posted on Jan 11, 2010
  • 16 Answers
There may be wear in needle seating in carb .also check float because they may leak in fuel an become heavy and wont shut off
Posted on Nov 11, 2008
I have a 17hp B&S lawn tractor that floods out immediately after starting up. I have to blow the carb out with shop air to dry it up and after several times, it will start....HELP!!!!!
Posted on May 08, 2010
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Do you have to prime a fuel pump after it has been rebuilt
when you put a new fuel pump on whatever type mower you are working on,yes its good to prime it a little so that your not cranking the juice out of your battery and easier on starter.when you prime it ,myself I put the new fuel pump on,and I pull the plug out and put a little fuel in cylinder head so when it fires it pump the fuel up faster to your carb! good luck!
Nov 12, 2014 | Briggs & Stratton Garden
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Gas icoming out of my muffler on my briggs 27 hp engine
must have trash under needle and seat and its not stopping your gas flow. you may have electric fuel shut off that's not closing it would be located under your carb. with a couple of wires going to it. check your oil level also it may be way past full
Nov 15, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Jul 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
19.5 model 917270821 won't start - not getting fuel. flows freely from where filter is and past but next section of tube dry- and clear what pulls fuel thru? it's getting past - but nothing in line section...
Hello mtcrew:
>>According to the Sear Site, this Unit has a Briggs and Straton Model 42E707-2631-E1 Engine Powering it.
>>You can View a Breakdown/IPL of this Engine at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM and Enter the Model (5 or 6 Digits) and Type Numbers (first 4 digits Only). Example: 42E707-2631. Then Double Click on the Model in the Results Area. Select Sectional Index. Now you can Select the Section of the Engine you Wish to View.
>>There is a Fuel Pump that is a Part of the Carburetor.
>>In the Breakdown of the Carburetor at the Site Addy I Provided the Fuel Pump Diaphragm is # 394A.
>>I Suggest you Lightly Presurize the Gas Tank and Force Gas to the Pump.
>>Sometimes the Pump has to be Primed before it will Start Pumping Properly.
>>Replace ALL the Spring Style Hose Clamps with the Screw Style Hose Clamps. The Spring Style Clamps Weaken and will Allow a Vacuum Leak to the Fuel Pump and the Pump will Not Operate Correctly.
Respectfully
John
Apr 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,253 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
