Question about Hitachi 50SBX78 50 in. Rear Projection Television
Rear projection child locked
Just installed [Hitachi] model 53sbx01ba ultravision,after auto channel memory completed 6" letters appeared indicating CHILD LOCKED, using a one4all universal, menu functions okay, PIP will show momentarily while demonstration is ongoing,tried just about everything I could without any service manual or any success.Would that the truth were otherwise.
    Genius:
  • 1,074 Answers
You had accidentaly enterd numbers into the tv and you do not remember.it dosnt matter what you do.you will never get it, the trick is that you will have to get the eprom or microchip lift off the set board to reset it self then put in back.that will solve your problem.good luck if you cannot do it get a tech.
Posted on Mar 27, 2007
SOURCE:
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
I need to find a remote for my model 53sbx01ba hittachi rear projection tv
Try Hitachi or even EBAY, almost any hitachi remote will work for the basic things, old remote will have number on the front if you want to search for the exact one.
Nov 28, 2012 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi Big Screen projection TV. turned off , wont turn back on
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com///
Sep 30, 2017 | Hitachi Televison & Video
Aspect
I have this same problem with my hitachi 55 inch ultravision luckily i have a warrenty still in effect so i called them and they said... Analog channels are not formatted for wide screen aspect (4, 6, and 10 ect.) this is a normal thing don't worry. It automatically returns to 4:3 because analog is full screen only, and it will return to 16:9 otherwise or whatever you have it set to. Nothing you can do but the good news is your TV isn't broken!
Sep 12, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi ultravision digital projection television
First try a hard reset to see if that will unlock it. Unplug the power cord for 1 hour; the power
Jan 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
