Question about Denon AVR-3805 Receiver
Component out doesn't work on Denon AVR-3805
I feel like I've tried everything, but it seems as though the component out (monitor) doesn't work on my AVR-3805.  Any suggestions?
    President:
  • 624 Answers
You can try resetting the unit, it is a procedure that can make things start working again. Be aware that it will put all settings back to factory defaults, and you will need to go thru and set everything back up again. If it does not work, then you most likely have a component failure that will require serious electronic troubleshooting and this would be best done by a professional.
Here is the reset procedure.
1. Turn power off with the main power switch on the front display, this should make the red led go out. There are 2 power switches on these Denon's. One is a bigger switch and is used most often, the other is a small mechanical switch that is normally left turned on at all times.
2. Hold down the "Direct" and "Pure Direct" buttons together (both at the same time) and while holding them down you turn the power back on again with that little power switch you just turned off.
You should see all the lights in the display light up and then it will turn on to the default setting which, if my memory is right, will be the tuner at it's lowest setting.
Then go thru and reset everything back the way you like it and need it. Make sure that all the video inputs are properly set for each function so you are not trying to get a composite signal out of a function that may be set for S-video or something like that.
Hope this is some help for you.
Dave
Posted on Nov 09, 2008
My denon avr 3805 has no hdmi ports. how do i connect my comcast cable box to it.
The only way would be component cables, and digital or analog audio cables. I believe there are HDMI to Component convertors as well.
May 12, 2014 | Denon AVR-3805 Receiver
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
Tuner not working - denon AVR 3805
turn left hand knob to select tuner (round knob on top left front side)
Dec 31, 2008 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
Video Monitor Out issues
Just to be clear, what is the input you are using on the projector?
Thanks,
Dan
Apr 18, 2008 | Denon AVR-3805 Receiver
Denon AVR 1803
Hello, I think that you've got a problem in the relay circutry or a logic problem. tell ya what I ve got the service manual and schematic for the reciever. the engineers at denon where ahead of there time when this company started. they designed the equipment around what they wanted the specs to be for signal to noise and discrete audio channels. each of the sound channels from the component and composite inputs is given its own bus and amplifier channels. these paths are also common to the reciever/tuner outputs. one question though you mentioned that the composite/component video paths are not switching from the input to the output youve designated, and that the monitor checks good. do you have another video source,either digital or analog that you can input throgh another channel to see if it is infact a switching problem. try that and let me know. I can give you help with the switching circutry form the schematic if need be. believe me I know It took me about a week to track down the service schematic for this unit. Denon doesn't like giving out info unless you are an authorized repair center.
Dec 17, 2007 | Denon AVR-1803 Receiver
Denon AVR-3805 Receiver Logo
225 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
