Question about Toshiba Satellite M30X Notebook
Dear Sirs , I have a Toshiba Satellite M30X-144 , when i press the starts button , he automatical runs like normal , but then a sound beep appear , like : b bbb bbb b , it means , 8beeps and the screen still black. Can you give some advice ? Thank in advance
SOURCE:
  • 5 Answers
SOURCE: Toshiba laptop won't wake up from stand by or hibernate
I had the same problem on my Toshiba Satellite U305, struggling with it for the past 4 months and having to use Shutdown each time I was done using it. Very frustrating! Toshiba worked with me several weeks, telling me to re-install Vista and all the fixes, which took a lot of work backing up etc and this did not fix the problem. Today they finaly told me to try entering this special command and it fixed my problem. Maybe it will fix yours too.
Create a shortcut on the desktop and to make the shortcut, right click on the desktop, choose Create Shortcut, enter CMD.EXE where it asks you to "Enter the location of the item". This will create an icon on the desktop that looks like a mini-command prompt. Then on the desktop, RIGHT click on the CMD.EXE shortcut/icon you have created and select "Run as administrator". This will open a command prompt window. Here in the black-box with white letter window, enter the command "powercfg -h on" (without the quotes). Reboot and see if the problem is resolved. This fixed my Toshiba Satellite that had this problem.
Posted on Jul 19, 2008
SOURCE: Toshiba Satellite A60
I have the same problem but when I enter the date and hit enter - it does nothing
Posted on Aug 04, 2008
Basilio00920
  • 155 Answers
SOURCE: Toshiba wont turn on, has beeping after i press power
Check the memory modules. Test one at a time to see if any of them is damaged. If you have only one, try a borrowed chip, or test yur modules in a borrowed laptop (it doesn't have to be the same brand/model, only the chips must be the same speed).
Posted on Apr 28, 2009
yboyandrei
  • 828 Answers
SOURCE: toshiba satellite a60 wont start.
replace your cmos battery inside... look for a technician for assistance to remove the cmos battery and change a new one... your battery is weak already
Posted on Jun 18, 2009
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
Pressing the CAPS LOCK or NUM LOCK there is a beep.
launch the Toggle Keys dialog box by holding down the Num Lock button for five seconds, and clicking Yes. Thereafter, a loud beep will sound through your computer's speakers whenever Caps Lock is turned on or off. (To turn Toggle Keys off, once again hold down your Num Lock button for five seconds.)
Nov 11, 2013 | Toshiba Satellite Computers & Internet
How do I do a complete restore on a Toshiba Satellite A75-S209
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Aug 21, 2012 | Toshiba Satellite A75-S209 Notebook
My toshiba satellite c660 19e wont start up to the log in it just says windows cannot repair this computer automatically i have tried restarting many times along with taking the battery out what can i do
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 13, 2012 | Toshiba Computers & Internet
Need manual for toshiba m30x laptop
Scroll down and click "Download the Manual"
http://www.retrevo.com/support/Toshiba-M30X-S181ST-Laptops-manual/id/614ci469/t/2/
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Toshiba Satellite M30X-S181ST Laptop
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Toshiba satellite M30X-155 audio problem
If your system has onboard sound you need the device drivers for your motherboard.
Jul 10, 2008 | Toshiba Satellite A135-S2276 Notebook
Keyboard
uninstall the driver and reinstall it.
goto:
start> control panel > admin settings> computer managment> device managment> human interface (keyboard joystick mouse etc...)
only uninstall the keyboard but realise when it is un installed it wont work! untill you reboot the computer and reinstall it.
good luck
Oct 29, 2007 | Toshiba Satellite M30X-S181ST Laptop
Toshiba Satelite Keyboard
Sounds like your contacts on your keyboard are dirty. Take some compressed air and blow it underneath your keyboard. Give it a good cleaning. See if that solves your problem.
Mike
Toshiba Satellite turn ON problem.
Remove the battery and then try to run your laptop direct from the mains supply, if this works it proves your battery is NFG and you need another.
Mark
Oct 16, 2007 | Toshiba Satellite M30X Notebook
Toshiba Satellite M30X Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
