Question about Sony KV-32S26 32" TV
KV-32S26 I had this Sony tv, everytime I plug-in to wall outlet, the fuse blow-up. I know there is shorted component into my tv. Could you please help me. Thank you, Mat Caringal Ontario, Canada
    Problem Solver:
  • 6 Answers
Shorted power supply ic regulator
Posted on Mar 16, 2007
    President:
  • 3,130 Answers
It could be a shorted thyristor, bridge rectifyer or a short in the horizontal circuit. if you have had no TV repair, play it safe and seek out a trained tech to assist you in this repair. if you want to learn read this nice artical I found at another site. good Luck http://www.techlore.com/article/15116/ PS please dont forget to rate this thread.
Posted on Oct 23, 2006
    Scholar:
  • 68 Answers
I agree with wayez, but there are other possibilities If you can get at the mains switch, check the mains wiring looks good and the switch operates with an ohm meter. See if there is a small mains tansformer in this mains wiring part of the circuit. If there is, it is quite likely the primary has burnt out, causing it to short circuit; the thermal trip will have reset which is in this transformer winding. Replacing this transformer is easy but make sure on switch on that its output is not shorted by another fault. Leaving a TV on standby shortens the life of these components. I have had lots of faults reported for TVs only 2 or 3 years old, so not only is your electricity bill more but it may cost you on average, 50£ or more a year extra due to a massive repair bill.
  • 4 Answers
It is definetly a power supply problem shorted bridge ,switched mode transistors DO NOT TRY to fix if you dont know what yor doing I got 30 years in it.GOOD LUCK. WAYNE
Posted on Oct 22, 2006
I have a Sony model KV-32S26 that will not turn on, been sitting for about 2 years. Had a tv repair guy tell me it was the flyback transformer. If that's the case, can I replace it myself? Thanks
1) You must test the a) fuse b) c.breaker inside c) diode, d) rectifier e) transformer f) filter. g) IC. regulator voltage and test it. If the problem persist you must go to the horizontal problem by lack of RASTER, now you test the transistor horizontal power, flyback. If you have some experience with the electronic you can try. If do not, better go to the repair shop Tv. Since you can have a electric shock by H.Voltage discharge.
God bless you
Oct 11, 2012 | Sony KV-32S26 32" TV
I have a sony bravia that I bought last month and it will not turn on
If you bought it new (model number indicated here is an older set) take it back----if used set someone will have to open it to see if fuse or power supply is the problem.
Mar 18, 2012 | Sony KV-32S26 32" TV
Sony trinitron KV-32S26 While watching the tv it went POP and the picture went pop. Is the picture tube shot?
not really..maybe an overloading of the secondary power supply could create this problem..check first the horizontal stage circuit for shorted component..before suspecting the picture tube
Jul 17, 2011 | Sony Televison & Video
Sony tv kv-20fv 300 power light just blinks
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Apr 25, 2010 | Sony FD Trinitron WEGA KV-20FV300 20" TV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
TV shut off Sony Trinitron KV-32S20
I believe this uit has a fuse on the AC input on the main PCB. Yu probably blew that fuse.
Jan 16, 2009 | Sony KV-32S26 32" TV
No power
Hi there!
Where you saw the Arcing, check closer to see wether the components are not loose on the board. You may only have to resolder the joints and problem solved. If the arcing takes place towards the tube, then you have a more serious fault. Thus involving High Tension, so I would not advise trying to repair that area if you are not familiar with TV repairs. Please unplug set before commencing any work. Regards and good luck, JUS004
Mar 31, 2008 | Sony KV-32S26 32" TV
Lost owners Manual
Click the link below. Scroll down to the bottom of the page & you'll see Product Details & just under that is Product Manual [2.29mb PDF]. Just click the link & it will start the download.
You'll need Adobe reader which is also a free download to read the .pdf file.
KV-32S26 32 Manual site.: http://www.amazon.com/Sony-KV-32S26-CRT-TV/dp/B00000JQCI
Adobe 8.: http://www.adobe.com/
Hope this helps!
Please vote...
Jan 26, 2008 | Televison & Video
TV does not turn on
If you have no indication of power(no lights,no clicks) the main fuse is a good place to start but if he is blown and is black in color you will have a shorted component ahead in the circuit and if you replace the fuse it will blow up as soon as you plug the set in,in all honesty since you are not too familiar with tv service you should be safe and seek the assistance of a servicer.
Oct 13, 2006 | Sony KV-32S26 32" TV
Schematic for a Sony KV-32S26?
Hi! I do not have the KV-32S26 Schematics, but I do have the KV 32S 22 schematics. Do u want those? there must only be minor differences. Or can u tell what the problem is and I shall try to send you the specefic circuit. mail me at 'guptapravin@hotmail.com' and i shall send the schematics as a mail attachment.
Sep 14, 2006 | Sony KV-32S26 32" TV
Sony KV-32S26 32" TV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
