Question about RCA 27V530T 27" TV
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
Whenever I turn on the tv, it plays a few mins. turns off, then on, and stays in autochannel search mode. I have pushed and held down buttons to get to menu, set tv in FRNT position,and erased all channels except ch. 3 thru vcr. Works for a while, then resumes autosearch again. I have removed back of tv, tact switches seem fine.
  • peggy galloway Nov 08, 2008
    tv model is 32v432t.
    I unplugged the front panel, blew off excess dust build up, pulled front panel buttons away from tact switches, and reconnected the front panel buttons. The tv has been working fine now for about 2 1/2 hours. Thank you for all of your help.
  • 899 Answers
Your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Posted on Nov 08, 2008
  • 2 more comments
  • jason Nov 08, 2008
    have you tried dis connecting the front control panel to see if it stops?
    please rerate the help as now fixya has made it so that even a helpfull rating hurts our rating and only a fixya helps our rating now , everthing else seems to hurt our score , sorry but thats fixya's doing,
    then i can tell you more, thanks
    electech
    ok,you will need to confirm some things for me ,like any dry or poor solder is resoldered , exspecially on heated components like the tuner, test the sensor on the control board , and transformer solders
    the most common fixes are the eprom,crystal, tuner, zener diode,resistors and bad solder connections and a few with the control board P001a plug socket soldered in backwards, check and resolder those that look suspicious
    then let me know the results
  • jason Nov 09, 2008
    cool! glad its going again!
    and glad to be of assistance!
Need a code for a RCA Universal Remote on a Broksonic Flat Panel TV
If you have the code book just hold the device you want to set up
like tv, vcdr, etc. and the power button at the same time. The power botton will stay lit. Put in your 5 digit code...hold it till the tv,vcr turns
off. Turn it back on and try the rest of the functions. If it dose not work
on certain function just hold down that key till that function works. Hope this helps.
Sep 24, 2012 | Broksonic Televison & Video
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I have a RCA TV 32v432t and when u turn it on it shuts off if u hit the side it will stay on ,is it dirt? i bought it used. worked for the first week
there probably is bad connection in one of the boards in the tv.
it's best you have this checked by a technician due to very high voltages in the set (26000 volts)
Sep 01, 2010 | RCA Televison & Video
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
Rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
32 in RCA turns on and off
your problem is in system control section or there might be a problem of loose connection in system control.
Sep 20, 2007 | Televison & Video
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
RCA 32V432T
FIRST THING TO TRY IS RESET-unplug AC cord for a few minutes,hours or overnight==let me know if you need more help.T.
Aug 04, 2007 | RCA 32V420T 32" TV
RCA 27V530T 27" TV Logo
229 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
