Question about Whirlpool Duet GHW9150P Front Load Washer
Getting a small plastic piece out of a door
The plastic latch of our front loading washer door broke leaving a tiny plastic piece inside where the door latches. We replaced the latch but we are having trouble getting the tiny plastic piece out of the hole. How do we get the little plastic piece out?
  • 5,911 Answers
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
My door will not open on front loading machine, flashing F and DL, I UNDERSTAND THIS IS A MALFunction, how do I get it open?, and is the fix something I can do myself?.
U can remove the lower kick panal on the frount of washer/reach up inside the washer to the door latch/ there should be a small round plastic tab coming out of the bottom of the door latch pull down on it that is the manual way of opening the door. Far as the f code it is most likely the door latch u can access it by removing the spring on the bellows at frount of washer. once in there remove door latch screws and wiring and reverse the steps to put back ...any more questions with it just ask ....and good luck....
Jan 31, 2011 | Kenmore Elite 45986 Front Load Washer
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
Can you reverse the door on the front load washer?
yes u can you will see some small plasitc pieces covering the holes on the oppisite side remove these plastic peices gently u willneed to use them on the oppisite side remove the door and the latch assembly u will see the same holes on the oppisite side make sure you install allthe plastic cover pieces back into the unit if not this is a great place for bugs to hide
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door stuck on lock cant open door.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. if you need step-by-step instructions on how to replace the door latch:
This advice is for replacing the door latch on the Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
May 03, 2009 | Washing Machines
Broken door latch
Why do you want to fish it out, the door might malfunction. I suggest you change the door lock mechansim, can do it your self.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Mar 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Mar 08, 2009 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
432 people viewed this question
Dan Webster
Dan Webster
Sal De
