Question about GE Dishwashers
Dishwasher will not start
Replace outer door skin, all wires plug in. lights on but will not start, display (88)
    Genius:
  • 1,011 Answers
Sir,
If your TV remote has a button marked CC or CCD or SUBTITLE press that button til the screen display reads "closed caption on" or something similar - if you get a black box on the screen without any print in it that means that the closed caption function is on but the show that you are watching is not broadcasting a closed caption.
thanks
good luck
Posted on Nov 08, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Nov 08, 2008
    Extremely sorry wrongly posted the message.......
    some of these units have a thermal fuse in line with and mounted on the
    control card. This will need to be checked. Also check the door
    switches. Some models will aloow power to the control card but to
    nothing else
    thanks
    goodluck
  • 958 Answers
What is the model number please?
tnx drcool
    Genius:
  • 3,422 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
    Sergeant:
    Novelist:
  • 196 Answers
Unplug the device for some time than plug it again and keep the door pressed with your hand and then ON.IT SHOULD WORK. THANKS.
How to take the outer door skin off
If you take off the outer door skin you will have to replace it. They are folded the welded around the inner frame. Generally a door skin removal tool is used to cut/grind the skin off. There are several youtube videos on this process as it is difficult to explain step by step.
Jul 31, 2016 | Pontiac Fiero Cars & Trucks
How do i take door apart, to tighten door handle?
Usually, you open the door and you see 4 or 5 screws that hold the inner and outer skins of the doors together. Remove those and lift the inner skin off. Tighten the handle screws and replace the inner skin.
May 04, 2016 | KitchenAid KGRA806PSS Gas Kitchen Range
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
My dishwasher started smoking from the tub area and got very hot. Now it worn't come on and there is a burnt odor coming from the tub.
Remove the phillips head screws surounding the inside of the door and seperate the door. Your model used a black mastic sound / heat insulation, which has most likely gotten soft and allowed the wires to become imbedded in it. The outer insulation on the wires can then start to disolve and short out, resulting in your burning smell, or in the very least error codes showing up on the display. LG would tell you to replace the inner door liner and the wiring harness, which is fine if you have a service contract on it (because the parts are not cheap, and the labor to change them is a pain), but it you don't have a service contract, you can replace the bad wires by splicing them to bypass the bad area(s). Then, use a felt type insulation between the new wires and the old mastic to prevent the same thing from happening again. Newer model dishwashers no longer use the mastic insulation, opting for a felt insulating blaket instead. Note: Other brands of dishwashers have had similar issues.
Feb 03, 2010 | LG LDF6810ST Stainless Steel Built-in...
How do I remove inner door skin to get at latch of Bosch Dishwasher SMS 2012
you dont remove inner door skin you remove outer, screws along both edges will allow outer door panel removal and the rest around the console will allow that to be detached showing the door latch in all its glory.
Oct 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Replacing front passenger window motor/regulator... Got inner door panel off, outer door skin bolts out, but don't know how to take off the outer door handle so the door skin can come off. Not very...
I don't think you need to remove the outer door handle.I hope this helps and google search a bit on it and you will get the answer.According to my experience,to replace the window you don't need to remove to outside door handle..Hope this helps.
Jun 16, 2009 | 2000 Saturn Ls 4dr Sedan
No lights displayed at all and the unit does not turn on. Tryed reseting the circuit breaker
It doesn't work at all If your dishwasher doesn't work at all, check these:
Door switch
Wiring
Mar 31, 2009 | GE GLD4460NSS Stainless Steel Dishwasher
REPLACE OUTER SKIN ON FREEZER DOOR
you can get a piece of metal and have it fastioned onto the freezer door with some adheasive like liquid nails. have them take and deburr the metal piece first for you.
Jan 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
REPALCE OUTER SKIN ON FREEZER DOOR
yes the door skin is avaliable here is the part #2222016W your looking at 200 - 250 dollars for this part.
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
