Question about Sony STR-DE595 5-Channel Amplifier
Surround Sound During video1, Movie mode; C.ST.EX A, only shows front; L,C,R and S speaker selection. I have rear speakers L,R not selected. How do I select all choices for speakers connected.
    Scholar:
  • 68 Answers
You must find on your setup menu the word `Surround', it may be `5.1 Surround'. Not `Stereo'(S ?).
Posted on Oct 23, 2006
SOURCE:
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Is there any upgrade avaiable to allow the Dolby Digital EX to remain ON (not AUTO) after the unit it reset? Per page 78 of the manual, it resets to AUTO, so I have to manually go into the menu to enable...
Enter the sound menu. Under the selection for extended surround, choose "on."
Then, under type select "EX/ES."
The way it is currently set for you, the movie software has to have a "flag" that your receivers' decoder must recognize in order for your rear surround speakers to function for a particular movie. Not all movies in DTS-ES or DD-EX have this flag encoded in it's software. So the rear surround channels would not be commanded by the software to be decoded and played automatically...thus requiring you to enable them yourself.
Setting it to "on" in the sound menu will take care of that problem.
Dec 31, 2009 | Yamaha RX-V661 Receiver
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Oct 27, 2007 | Kenwood VR-309
Sony STR-DE595 5-Channel Amplifier Logo
180 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
