Question about Samsung SlimFit TX-T2782 HDTV
Samsung slimfit txr3079wh
Has repeating vertical wave ( darker color) across tv traveling from left to right
  • Anonymous Dec 08, 2008
    WHite lines though screen, it flashes constantly then turns off. terrible product
  • BUBBLEZZ41 Dec 11, 2008
    I HAVE THE SAME PROBLEM...SUMBODY PLEASE HELP!!!!
5 Suggested Answers
SOURCE: Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
Posted on Jan 19, 2009
  • 98 Answers
SOURCE: samsung slimfit keeps turning off
When the TV is on, how about the back light(you can check that on your TV's back side)
If the back light on -- need to replace Main Board.
no back light -- need to replace Power Board
Posted on Feb 24, 2009
SOURCE: my samsung slim fit tv has a horizontal line which
cordless phone base was too close and was giving interference to the television moved away and solved
Posted on Sep 21, 2009
SOURCE: my samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Posted on Nov 30, 2010
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
Tip
How to Format an HP Recovery Drive
How to Format an HP Recovery DriveThe HP Recovery Drive is a partition HP puts on its hard drives for use in case the primary partition becomes corrupt or unusable. The recovery partition contains system files and the ability to boot and repair, format and reinstall the operating system if needed. For those who prefer recovery disks or who don't feel the need for the insurance of the HP Recovery drive, it can be formatted by following the steps below.
Instructions1 Open Disk Management by Right Clicking "My Computer" and selecting "Manage."
2 Click on "Storage" and "Disk Management."
3 Find the Recovery Drive partition. There are usually two partitions: the "C: partition" and the "HP_RECOVERY D: partition."
4 Right-click on "HP_RECOVERY D:" and select "Format."
5 Choose the File system and Allocation Unit Size and click "OK." The HP Recovery Drive partition will format and be available for your specified use
Tips & Warnings
Be very careful to not format the C: drive by accident.
on Dec 15, 2011 | HP Computers & Internet
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Picture out of screen
IF picture too high top and bottom look in vertical circuit---if left and right it is in horizontal circuit.
Apr 10, 2012 | Samsung SlimFit TX-S2783 TV
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Feb 08, 2011 | Samsung SlimFit TX-T2782 HDTV
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Dec 28, 2008 | Samsung SlimFit TX-S3082WH 30" TV
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung SlimFit TX-T2782 HDTV Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
