Question about Philips CDR775 2-Disc CD Recorder
Every disc reads no disc in the left recording tray
I put in brand new blank Sony cdr and it reads it no disc 98% of the time.
  • 1 more comment
  • Anonymous Nov 21, 2007
    I tried over and over again, took the power of the recorder and back again, tried new discs, tried my own made discs, tried discs I bought in different shops, etc.
  • efgbet Jul 02, 2008
    power is on but not disc read and stop every think.
  • keithbyrne08 May 20, 2009
    reads no disc in left tray
Try to use phillips discs
Posted on Feb 16, 2007
WHAT  DISC  DOES  IT  NEED ?
Posted on Feb 25, 2009
My disc wont read in any of the drive it reads no disc
Posted on Feb 12, 2009
SOURCE:
How do I get my Sony RCD-W1 to record from one CD to another
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
Dec 09, 2012 | Sony RCD-W1 2-Disc CD Recorder
COPT CD
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Oct 06, 2008 | Sony RCD-W500C 5-Disc CD Recorder
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Mar 01, 2009 | Philips DVD724 DVD Player
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Cdr s1000 help
Hi Rick
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
regards
Graeme
Apr 06, 2008 | Yamaha CDR-S1000 CD Player
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Problem with Sony RCD-W1 CD recorder
Are you copying a disc you have previously recorded? SCMS will prevent this.
'No disc'on the CDR deck usually means the laser is faulty.Can you hear it spin the disc? When you open the tray has the disc been rotated? The sony's laser is usually reliable. Sony US may have a fixed price repair or you can have a look yourself. I have the service manual should you need it.
Feb 14, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Phillip CDR778
You can try other brands of audio cdr but it sounds like your laser is on it's way out. Some find cdrw's still work after cdr's have stopped being recognised.
Dec 29, 2007 | Philips CDR778 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder Logo
1,053 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
