Question about Kenmore 15129 Built-in Dishwasher
Kenmore Ultra wash ll
I don't know how old the dishwasher is, it was here when we moved in. I loaded the washer and it got part way through the wash cycle and never finished. It has water standing in the bottom and won't empty out or run. We have done 100's of load in the dishwasher before( we have been here for over 1 year) and never had this happen before. How can I fix the problem?
  • 2 more comments
  • lynnepaula Nov 13, 2008
    I know the power is good, I tried another outlet that I know works. Can you tell me where the panel is to remove and how to get to the circuit board. I don't know anything about this type of stuff.
  • maxmeeker Dec 10, 2008
    Same exact problem as state above
  • andyross33 Dec 24, 2008
    I have the same problem. Wife opened up during the cycle to get a cup, and now the washer has water sitting in bottom with what appears to be no power at the controls (no buttons working, no LEDs working). Checked the power to the unit and of course that is not the problem.
  • jjrose2001 Dec 29, 2008
    I am having the same problem with water remaining in the tub after my dishwasher goes through the entire cycle. How do I get it to drain?
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds as if you may have blowna fuse on the control board, i would check incoming ower supply first for 110v. if power supply is good i would reomve the panel and check the circuit board for a a fuse that might have blown little white fuse attached to the side of the electronic control
Posted on Nov 11, 2008
  • Ron Coons
    Ron Coons Nov 14, 2008
    i suggest geting someone with a little bit of mechaniacl knowledge, wouldnt want to reccomend a reapair in which you may get hurt/electrocuted trying to save $100
How do you open the soap dispenser on a Kenmore Ultra Wash dishwasher?
Push the little lever sticking out of the dispenser.
Maybe you have some calcium or hardened soap that is holding the lid closed. some Lemi-Shine powder dissolved in hot water and use an old toothbrush to clean off the soap/hard-water deposits.
Jul 27, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore ultra fabric care ll heavy duty 90 series. Will not drain after washing.
If this machine is new or old sometimes wash items get out of the basin and clog up the pump. This may not be the problem in your case. Let's look at the pump. Is the belt tight? Sometimes you can see into the pump ,is there something visible in the pump preventing it from turning? Is the belt worn to the point that can't turn the pump pulley? With belt off pulley ,can the pulley be turned by hand one way or the other, I mean is it seized?Check these suggestions, and get back to me with how you made out. GOOD LUCK.
Aug 29, 2011 | Kenmore 23822 Top Load Washer
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Oct 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
Jun 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 15129 Built-in Dishwasher Logo
216 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
