Question about Kenwood VR-715 Receiver
Record Player has minimal sound
Hello I recently hooked up a record player to my VR-715 and for the life of me I can't get the volume up. I have re-set everything according to the steps in the manual a number of times to no avail. If you crank the volume it stays at a low level. Anyone know why this is not working? Thanks.
  • Kenwood Master
  • 5,515 Answers
Has the VR 715 got a dedicated phono socket? If so use that. If you are using it, you need to check with the instructions to see if it has an inbuilt Magnetic Cartridge Preamp. If it doesn't then you need a to get a pre-amp to hear it.
If the device was previous giving out good sound then either the cartridge has gone or the same pre-amp inside the unit has failed. It will not affect any other function.
To test the cartridge. Remove the connection wires to it remembering where they connect (write it down). Then with the device on. Switched to phono. Touch the end of each wire with your finger one at a time. You should hear a loud buzz on two of the wires, one on each channel, nothing on the other two wire.
If you get the loud buzz that shows the pre-amp is working and the cartridge needs to be replaced. If you do not get a buzz, or it is very weak. Then the pre-amp has failed and needs replacing.
Posted on Feb 09, 2018
4 Suggested Answers
cancerags
  • 36 Answers
SOURCE: Kenwood VR-715 reset?
Hello llarosa,
Yes, there is. Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER ON/STANDBY key.
That will clear the contents of the memory, reset the microcomputer and take the unit back to factory settings. Hope this helps. Let me know.
cancerags
Posted on Dec 31, 2007
  • 87 Answers
SOURCE: I've had a Kenwood VR-407 receiver since 2000 and
More than likly there is a bad component in one of the output circuits that is activating a circuit protection feature of the device, this is actually a good thing and is telling you it needs help. I can't tell you what the component is, but it is definitally something a service tech should take a look at. Chances are it's a bad cap or a failing resistor, but there is a good chance that it's the power supply as well.
Posted on Oct 28, 2009
Testimonial: "Thank you for a speedy and precise response!"
  • 85 Answers
SOURCE: How do I connect my
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Posted on Jan 08, 2011
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Audio Players & Recorders
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Low Sound from Kenwood Record Player when Hooked up to Amp
Make sure the player is grounded to the amp chassis. Use the ground side of the AM antenna. Use the phono input of the amp, not a tape, CD, or DVD. The signal from a record player is much lower, hence, if you use the phono input for a tape player it is noisy and loud. Clean the needle too. I hope this solves the issue.
Aug 23, 2009 | Onkyo HT-S4100 Theater System
How to record a tv show to my go video Vr 3930 dvd recorder
i have a coax cable output from dvr to input to VR3930. I have to play the recording (i.e. watch the recording) and record on dvd. does work, but I can only get to record in mono - no stereo.
Aug 12, 2009 | GoVideo VR3930 DVD Player/VCR
Samsung dvd vr-357; recorded DVD only plays on the player
You have to "Finalize" the disc before it will play on other units. Go to Disc Menu, Second choice listed(not in front of it right now) Selections to right will offer disc Finalize. Say YES.
Jul 19, 2009 | Samsung DVD-VR357
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
Unit will not record on blank DVD-Rs. No problems until recently. Cannot set up or finalize DVDs after recording efforts.When I click on VIDEO (vs. VR) Unit will not change over for formatting.
There are a lot of similar complaints about your unit, which gets only 3 out of 5 stars on some review sites
and though it says sansui you should not confuse it with the brand known in the seventies as a quality
line, as it is a sub-brand of Orion, now. The unit employs an ide computer type dvd recorder which can
be replaced if you know what your are doing, to minimize your costs, since similar complaints arise after
only three years of use with this unit, and that method of resolution has been tried and succeeded.
Apr 11, 2009 | Sansui VRDVD4005 DVD Player/VCR
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Kenwood VR-715 Receiver Logo
42 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
