Question about Kenmore Refrigerators
Refridgerator and freezer stop cooling
The freezer thaws out and then starts up and works for about 12 - 16 hrs making ice, freeezing everything, etc. Then it preceeds to defrost and thaw everything and now the fridge has quit again too
  • 958 Answers
Inspect first the condenser at the rear or at the bottom back of the freezer. see if it is full of dirt and trash.
if it is, clean it and it could just be the problem.
if not, then observe the unit further, adjust the thermostat first to the coolest setting just to eliminate the problem with the thermostat.
keep me posted.
tnx 4 using fixya,
drcool
Posted on Nov 08, 2008
  • francis rivero Nov 09, 2008
    hi mickey,
    i'm not sure you know how the ratings work, but the ratings are as important to us as answering your questions, and a rating of Thnaks For Trying ( TFT) would give me a minus 0.4 in my rating where as a Helful would just give me a minus 0.1. and since we are still in the process of solving your problem, can i just ask for a Helpful this time since i can really help you on your problem.
    tnx in advance,
    drcool
Model mtb1950gr. Freezer stopped working. Fan is blowing cool air up there, but everything is completely thawed. Refridgerator part below it seems to be working fine. Vaccumed back.No change.
Your defrost may be stuck on. Cool air is not the same as freezing air. Frost free freezers use less than freezing air passed over and through the food to warm any ice crystals and move the moisture out of the freezere.
Apr 03, 2016 | Maytag Refrigerators
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
Our Kenmore is a side by side with ice maker. It's about 6 years old. The ice maker quit making ice about a year ago. We didn't get it fixed. Now our refridgerator section won't cool. The freezer works...
Find the vent in the refrig that gets the air blown in from the freezer. When the unit is running you should feel air coming out of it. If not then you have a problem with the damper door. you can manually open the damper door but you might have to adjust it so it does'nt send in too much freezer air and freeze stuff.
Sep 08, 2009 | Refrigerators
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
