Question about Whirlpool Washing Machines
No water for rinse cycle
The washer fills fine at first. At the final rinse, just a trickle of water come out.
  • 1,543 Answers
Take the fill hoses off the machine and clean out the filter inside, right where the hose attached to the machine. Also, check to make sure there are no filter washers in either end of the supply hoses. Sounds like you only have to check the cold water side in this case.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: just a trickle of water during rinse cycle
You write that the water flows fine during the wash cycle; if you mean while the machine is washing, then it is the pump  making the water flow. You need to watch the water flow while filling for any cycle since it could be slow filling and not running.
Since the same valve(s) control the water intake during washing and rinsing, what you describe doesn't make sense. I suggest your remove both ends of both hoses and inspect them and the mating connectors on the machine for clogged screens.
If these are clear of any sediment, then the flow control valve is failing. This is located on the rear of the machine and the screw connections for your hoses are part of the valve body. This assembly is pretty easy to remove and replace, is a common and not very expensive failure.
If you are in the US, check to see if you have a Johnstone Supply in your area. They sell mostly wholesale to tradesmen but have never turned a private sale away and are far less expensive than dealers with pricing ranging from 30-50% of dealer price.
Posted on Oct 12, 2008
vitg55
  • 78 Answers
SOURCE: Hot Water runs in fine but the cold only trickles into Washer,
The problem is your cold water screen filter is cluged up.
To fix it:
1. Shut off cold water to the washer.
2. Take off cold water fill hose from machine side and faucet side.
3. Inspect the screen filters on the hose and inside water valve.
4. If necessary to clean them remove from hose and valve with pick or small screwdriver.
5. You can clean them with old toothbrush under water stream.
Posted on Dec 02, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
buffalonyman
  • 1865 Answers
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Posted on Apr 25, 2009
garing
  • 998 Answers
SOURCE: My Kenmore 80 series top
clean inlet valve screens
Posted on Aug 25, 2009
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
Sep 20, 2014 | GE Washing Machines
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
Cold water in the rinse cycle of the washer just trickles
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Water barely trickles out for rinse cycle
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
