Question about 2wire Wireless-G 802.11g ADSL Gateway
Wreless connection is detected and connected but no internet
I got a newAT and T DSL and set up the 2wire. It works good on my desktop that is hard wired to the modem, but my laptop is not connecting to anything. It detects and connects to the network, but wont do anything with it. It has an IP address and is even sending and recieving packets. Not sure what to do.
    Problem Solver:
  • 12 Answers
Most likely there is a problem with your pc, try turning off your wireless card wait 30 sec. and then turn it back on if it gives you a valid ip which should be a 192.168.... number than there is nothing wrong with the connection, if you are using a windows xp go to start and then run type in services.msc click ok maximize the box scroll down to the bottom you should see wireless zero config, right click choose properties click stop if the service is started click start if it is not, if it says the service is started then click stop and then click start again, then click ok restart the pc if it is vista you are using you will go to your start button->all progrms->accessories->run and then follow the instructions above, if that does not work go back to run (for xp) and type in cmd (for vista right clck on command prompt under accessories and choose run as admin) then in the black cmd box that pops up type in netsh int ip reset resetlog.txt wait and then type in netsh winsock reset restart the pc and attempt to surf , if it is still not letting you contact the pc manufacturer.
Posted on Nov 15, 2008
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
When connecting 2wire wireless dsl light and internet light both stay red, unless i remove the dsl line from the dual filter then light turns green, but either way my Lap top does not respond and says no...
It's possible that the filter could be defective, and it's possible that the telephone line could be interfering with the dsl or signal. Once you have established a good connection, and you now have a green dsl light, you can update the username and password by launching into your modem with the following ip address: 192.168.1.254. Type this on the address bar of your internet explorer. Once you're inside the modem, click on Broadband Link and click Advanced Settings. Update the username and password that which could be you're email address with AT&T and Network password which is provided by your ISP as well. That should get you connected .
Feb 02, 2011 | 2wire 2700HG-B Router (2700HGB)
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
AT&T 2Wire 1800HG set up on Ubuntu
https://help.ubuntu.com/7.04/internet/C/connect-to-internet.html
Jan 03, 2010 | 2wire 1800HG Router (RG1800HG00)
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway, 192.168.1.254
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping 192.168.1.254 and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Aug 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
140 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
