Question about GE WSM2700D Top Load Stacked Washer / Dryer
Kenmore stackable model 417.98702891
We have had problems since the 1st day we bought the machine (1999). Today the washer will not start, it will not do anything. The dryer is fine but the water will not come in the machine, no nothing. My husband and I cleaned the inside of the machine really well and the control panel but it still is not doing a thing. We still have the control panel off so we would like to try to fix it before putting it back together.
Thanks!
gittos73
  • 244 Answers
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Posted on Dec 12, 2007
huuum
  • 750 Answers
SOURCE: GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Posted on Oct 04, 2008
MNTECH
  • 1543 Answers
SOURCE: GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Posted on Dec 10, 2008
SOURCE: GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
I have a GE MODEL WWSe5240G0WW top loader washer that has seen very little use. My problem is that the unit will not agitate or spin,every thing else seems to work ok. I did remove the top lid switch and jumped the to wires (Yellow/Red and Orange) still did not make any difference. Any in for would be great.
Posted on Feb 21, 2009
  • 53 Answers
SOURCE: Does the dryer make a loud noise at the end of the
it should make a loud buzzing noise
Posted on Nov 05, 2009
I've got a stackable Heavy Duty Kenmore washer. It's not that old, has maybe been used 50 times. The washing machine fills normally with water but when the the wash cycle should start, the macine just...
I recently worked on one of these and took some photos of the dryer fix. I added 2 service manuals. I figured someone might want to know how to get into the machine and do some repairs. Click HERE
Jan 01, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer spins, but not as fast as it should. The
Check the drain pump and /or filter not jamming / blocked
Nov 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
GE WSM2700D Top Load Stacked Washer / Dryer Logo
573 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
