No matter which size load is selected or if left for the machine to decide, the washer does not fill with enough water. If a medium size load is in the washer and extra large load is manually selected, then it usually fills with enough water. This is the only way to get enough water in it. I have to manually fill the washer with water for every wash and rinse.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Thank you all for your suggestions. My husband removed the water level switch and can move the dial manually from setting to setting. However, when he put it back in place, same problem. Setting the dial to small and medium produces the same amount of water. I will ask him to check the hose that connects to the water level switch for any obstruction. I think the water level switch needs replacement. But wanted to check.
SOURCE: maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
SOURCE: Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
SOURCE: washing machine overflows no matter what load size
there is a sensor that tell the valve when to turn on and how much water should go thru the machine, it is a selinoid valve in the water line with a wire commming out of it,, you will either need to replace this your self or have a tech come out and tend to it
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
