Question about Canon i9900 InkJet Photo Printer
Smudges on both sides of paper
I just asked you how to get rid of the smudges on both sides of the paper on our i9900-- and you said to clean it. That much I figured out... what I need to know from you is HOW I clean it-- the exact procedure-- or the 10 dollars I just spent is wasted... Thank you for your help.
    Sergeant:
    Novelist:
  • 196 Answers
In the area from where the printout comes.just lift the printer cover and u can see the area from where the paper exactly comes out when you give the printout.the area is black in colour and the length of that black area is near to 12"inches.and there are small steel like fittings in that area.you ust have to clean that area of steel and also the sides of that steel area.u can clean it with isoprophyll and tissue paper.just OFF the printer and then take some isoprorhyll in the tissue and rub the wet tissue on that area properly.
if this does not helps the printer needs to be opened and that cleaned part by part.
taking it to the repair center is much advisable.as your printer is absolutely ok.and just needs servicing it will not be to costly.
Posted on Nov 08, 2008
Canon I9900. Why isn't it picking up paper?
check to see if nothing has fallen inside via the paper input from the top.you may have to open it.you might find an office pin or pen or its cock or any other thing that has fallen inside...a printer tech like me can solve this problem.
Jun 14, 2015 | Canon i9900 InkJet Photo Printer
Smudge marks on left side of paper?
If you use new original toner, this should not happen, nevertheless, clean the drum first.
Sep 04, 2014 | Brother Laser Printers HL5450DN HL-5450DN...
I have a smudge on the right side of paper when printing on my lexmark E250dn printer. How can Iget rid of this smudge?
You have a mark on the drum. Find the drum cartridge and rotate the drum by the gear until you find a mark on the surface of the drum. You can try wipe it off with a very soft dry cloth but it is unlikely that this will be a cure and you will probably have replace the drum cartridge (+ $70). Do not try to clean it with any solvents or polishing material.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Black smudges across sides of 81/2 x 11 paper
The optics may be dirty or you could have a bad drum cleaning blade.
Feb 13, 2008 | Office Equipment & Supplies
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
122 people viewed this question
old marine
old marine
