Question about Compaq Presario 2140US Notebook
Can't boot up laptop
I have been unable to boot up my laptop. When I turn it on, the screen is black (it looks like it's off, not like a "lit up" black) and the hard drive light does not turn on or blink and I can't hear the hard drive spinning. The fan occasionally goes on and off, like usual. I don't think there is a problem with the power because the power light goes on and I can also charge my ipod through the USB connection. Before all of this happened, I was just using my laptop like normal (I haven't installed anything new or added anything to the laptop for months) and then my laptop just turned off by itself and started to reboot. However, it would never fully reboot; it would just keep turning itself off, then start rebooting again, then turn itself off and start rebooting again. When it was doing this, it never rebooted to a point where I could see anything on the screen, like the Windows XP logo or the Compaq logo. A couple days before this incident, I heard a single beep from my laptop as it was booting up. I'm not sure if this is related, but I thought it might be worth mentioning. Any help would be greatly appreciated.
    President:
  • 2,961 Answers
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Posted on Oct 23, 2006
  • andrew pester
    andrew pester Oct 23, 2006
    If you can get to your desktop, you can try using system restore(start> programmes> accesories> system tools> system restore)and try restoring back to before the problem started.
    You will not loose any saved documents.
SOURCE:
PC turns on but will not boot up; unable to run directly from cd rom
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
Toshiba Satellite l445d-s5976 won't power on
Well,that happend to my mom's computer and it was all working and was turned on but the image on the screen didn't show so I'm not sure how to fix it but I think you should send it to repair the same happend to my TV and it was sounding but didn't see the screen so I think the best thing you should do is sen it to repair or drop it off at Best Buy
Nov 24, 2012 | Toshiba Satellite L455D-S5976 Notebook
Compaq Presario CQ60 screen is black
also make sure you're not in presentation mode, my vostro (winxp) would randomly boot to presentation mode and turn off my monitor....
upgraded to win7 and it stopped doing it...
Oct 03, 2012 | Compaq CQ60-215DX Notebook
Hi, I have a Fujitsu Siemens Amilo Laptop. I have a serious problem with the screen. Every time it boots up the screen stays black, but I can hear it booting up. Anybody here any idea what the problem is?...
Look closely, you should be able to see the Windows desktop.
The fluorescent backlight is not lit up.
The lamp may be blown (not likely) or the inverter cable connector is loose.
Power OFF the laptop and remove the battery & power supply.
Remove the keyboard bezel.
Follow the cable from the screen to the motherboard. Re-seat the connector.
Assemble & power up.
Oct 06, 2009 | HP Pavilion dv6000z Notebook
THE LAPTOP DOES NOT BOOT
its a sensitive problem, 1st remove your CD-Rom drive then start your laptop, if consist then open the skrews of hard disk portion and remove it also then open your laptop it will display the screen.
otherwise contact your hardware doctor.
shafky
Jun 17, 2009 | Computers & Internet
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
TOSHIBA A125 LAPTOP POWER STUCK UP
hi venji,
you question was still not clear. If I'm not wrong you mean to say after 20 mins your computer screen when black and you could not see anything, right ???
did you try to touch the power buttton to turn it on again maybe its in sleep mode.
Or you mean after 20 min..laptop still work but you hardly can see due to no light (back light )??
so I'm not really sure ..please give us more detail.
takecare.
May 29, 2008 | Computers & Internet
problem with ur memory(RAM)
Dec 03, 2007 | Gateway 450SX4 Notebook
Compaq Presario 2140US Notebook Logo
317 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
