Tv turn off cant turn on model# pth5498 serial#392t950434x
  • 1 more comment
  • jbody06 Nov 08, 2008
    theres no power bateries on remote r new and tv is conected
    how can i fix or trouble shoot it the power supply
    yes check fuse that was it tv working thanks
  • 19,396 Answers
The TV does not turn back on because a fault had been detected, and now the TV is in protect mode.
On a rear projection TV like this there are many faults that can cause this.
Try leaving the TV set power cord unplugged for two or three hours, this will drain power from the unit, and reset the protection switch if there is no real proble.
If it does not restart that means that there is a fault.
Unless you have tested components on such a TV before, it is better to call a technician, this is an expensive set.
If you want to call support you can use the phone number listed on the owner manual. If you ring them you can also ask Akai the price and modality for an extended warranty, or an extended assistance plan.
This will cover repair and parts expenses for one extra year, and it is usualy less expensive than a single repair job.
Posted on Nov 08, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Unplug the tv poercord from the electric outlet first.wait for 10 minutes.remove all the external wires of dvd players vcd players or any other devices connected to the back of the tv.check out any other electric device in that poer outlet and see if it is working properly.if the device is working properly , then plug the tv wire in the electric outlet.and ckeck out mostly the tv get resetted after removing the wire and reinserting after sometime and starts working. but if the other device you connet to check the power outlet does not work that means the socket is faulty.so you connect your tv wire to any other electricsocket. if still after doing all this things the tv does not work.then the problem is internal/ the fuse on the main board must be blown off.or the board has shor circuit on it and it needs resoldering.check it out. thanks.
    President:
  • 1,314 Answers
The power supply or the power board on your TV is bad. It will need to be replaced.
    Brigadier General:
  • 3,614 Answers
Did you still have any power coming on the tv...
first check the power connections. and replace the battery remote too.
  • micromaster
    micromaster Nov 08, 2008
    you mean that there was no power on the TV..
    1st check the tv plug and wire for any damaged and also check if your outlet is now faulty.
    if this was all check and no problem was seen, then you were having a problem on the power supply area of the tv.
    in this case i may advise you to call someone who can do the work for you, it was not advisable to service the unit if you have no idea how to repair such television.
  • micromaster
    it is very dangerous to service and repair inside the tv cause there was still high voltage electricity sored inside, and this will be so risky if you will try to serice it on your own.
    you better call a repair guy for this job.
I have the pth5498 and my tv won't turn on. My
Timer is not the problem---the tick ticking sound is the shutdown circuit in the set that has been triggered by a short somewhere likely in the high voltage area or the convergence circuit---shop repair---says Akai but I suspect set was made by Samsung who owned that name at one time.
May 25, 2012 | Akai Televison & Video
AKAI model PTH5498 turned it on in morning and it worked fine, then went to kitchen then heard a pop then a buzzing noise tv had no picture
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
May 17, 2012 | Akai PTH5498 54" Rear Projection...
Okay, so we have the TV and it's the PTH5498, we are under the impression that it's hdtv ready but... we lost the manual so how do you turn it on??
If ur tv is a HDTV.HD tv signal u don't turn it on u have it or not.Check ur tv imcomming broadcasting signal like 1080i or 1080p.u can get that signal,if ur tv in HD broadcasting.
Apr 22, 2011 | Akai PTH5498 54" Rear Projection...
Double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Akai PTH5498 54" Rear Projection...
Black line at the top of tv
MUTE 1 8 2
or
MUTE 1 8 3
Look for vertical adjustment
Be careful, no factory reset if you screw up
Write down old value before adjusting
Dec 20, 2007 | Akai PTH5498 54" Rear Projection...
Akaia PTH5498
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Akai PTH5498 54" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
