Question about Ricoh Aficio SP-C210SF Printer
Unable to Print error
Black toner was leaking, Cleaned unit, replace toner, now unable to print error message. The book only says shut down and restart, does not work.
Thanks garry
  • 1 more comment
  • hmalone Dec 31, 2008
    I'm having this same problem.  I have checked the life of all of the consumables, and they are in good shape.  I even tried removing the parts and reinserting them - no luck.  I now have all power turned off and removed.  I'm going to leave off power for a couple of days and see if that resolves the issue.  Anyone else seen this happen?
  • giopeco88
    giopeco88 Aug 29, 2012
    any news? i've the same problem :(
  • giopeco88
    New Friend:
  • 63 Answers
Try resetting the print jobs from your computer printer que and also resetting all jobs from the printer side also good luck
Posted on May 01, 2009
I have replaced waste toner unit with new one on a WC 5050 and still shows the error message as full so unable to print
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer.
NOTE: This should solve most problems with printers.
If still not working you have a faulty Toner unit.
Sep 21, 2013 | OKI C9600hdn Laser Printer
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Print unable 32
This is not just a density sensor, this is a plastic cover over it that is getting stuck. There is a piece of soft rubber attached to the solenoid that is getting very sticky over time. Removing this rubber and stretching solenoid return spring corrects the issue. Search web for the service manual and follow chapter 8 to disassemble the printer correctly - takes less than 10 minutes to do it
Aug 29, 2011 | Brother HL-4040CN Laser Printer
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Dec 18, 2008 | OKI C9600hdn Laser Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Ricoh Aficio SP-C210SF Printer Logo
416 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
