Question about JVC TH-M505 System
SUBWOOFER WON'T POWER ON (Grounding out???)
I have a JVC TH-M505 system. I am using all the factory speakers as well as the factory subwoofer (which runs all of the speakers) I was redoing my floors and I had to put the subwoofer on the fireplace until I finished where the subwoofer was - I put the subwoofer back down on the floor, and now when I turn on the unit, the Subwoofer light comes on for about a second or so and then turns off. I suspect that maybe it is grounding out or something but don't know how to resolve it. I have disconnected, and reconnected the speakers, changed the outlet I had the subwoofer plugged into and nothing changes. ANy help or suggestions would be greatly appreciated.
  • 203 Answers
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Posted on Jun 15, 2007
SOURCE:
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
JVC Home Theater System M505 The subwoofer will not come on and it appears that the system (speakers) will not work at all until it runs thru the subwoofer system.
Wiggle on the long round cable connected to the Sub woofer. If the SW turns on, open it and solder the connector or change the connector
Jan 18, 2010 | JVC TH-M505 System
JVC TH-M505
There are very few uses for the subwoofer. Try it on FM if you get audio the woofer is working.
Apr 22, 2008 | JVC TH-M505 System
Jvc th m603 center unit - powered subwoofer
Yes go to JVC.com It will cost you $20.00
Mar 30, 2008 | JVC TH-M505 System
Jvc
i need a jvc subwoofer
Jan 29, 2008 | JVC TH-M505 System
JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Jan 12, 2008 | JVC TH-M505 System
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=30&modelId=MODL027222
cut n paste the link for the manual
Are headphones plugged into it?
Is the headphone jack damaged?
Are there speaker fuses on this model? If so, check them.
Dec 06, 2007 | JVC TH-M505 System
JVC TH-M505 System Logo
589 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
