Question about GE DBSR453EBWW Electric Dryer
My dryer is making a horrid noise
My dryer is a ge dpsr483ea1ww and its making a horrible grinding noise when it is on. Is it the belt orsomething else.
  • 958 Answers
Belt would squeak. but a horrible noise would probably be coming from the gear box. it may need a simple lubrication to the worst of replacing the whole gear box.
check it underneath the tub. if you can remove the housing and run it while it is open and see or hear where the noise is coming from. be careful on the moving parts once it is running with out a housing.
tnx 4 using fixya,
drcool
Posted on Nov 08, 2008
  • 1,543 Answers
It appears drcool299 didn't notice that you are talking about a dryer, not a washer. Belt problem, not likely. Disconnect power. Open top by using a putty knife to push in the seam between the top and the dryer front, about 2 inches in from each side and lift top up and off. Remove two screws holding front onto sides of dryer, near the top. Tilt dryer front forward and lift dryer front off the bottom pegs and swing dryer front to the side. (you don't have to remove the switch wires if you don't want to) Check the teflon drum slides at the top of the dryer front which supports the front of the drum. They may be worn out and the drum may be wearing into the drum support. There may be sand or an object caught in by the felt seal. If all that is OK, you can unhook the belt and pull the drum right out the front to check the back drum bearing or make sure that an element is not scraping on the back of the drum.
My frigidaire fer231cas2 makes a horrible loud GRINDING noise after its been running for 10 or so mins
Hello friend, thank you for your post!
I see that you have changed multiple parts within your Frigidaire dryer due to a grinding noise. Since you have changed the bearing cup, felt, pulley, and belt I would recommend having a technician come out to diagnose your appliance to avoid any further unnecessary part purchases. You could be seeing an issue within the drum or motor. I hope this information is helpful. -Matt
Aug 26, 2014 | Frigidaire Dryers
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
My dryer making squeaky noise we open to check the belt. Belt is fine where should be the noise coming from?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 31, 2011 | GE Profile Harmony DPGT750EC Electric...
I have a GE electric dryer and it makes a horrible screeching noise when tumbling. it tumbles and gets hot but when trying to manually turn the drum it gives me some resistance. whats the making this...
heatman101
Jul 25, 2011 | Dryers
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
Our Hotpoint tumble dryer has had a new drum and belt put in 4 days later it is making a horrible grinding noise.
Its possible that the noise is comming from the movement of the drum,the motion of the motor,belt pully or drive spindle.It will be good to reassemble and manually check the moving parts for the noise.
Sep 29, 2010 | Hotpoint Dryers
The dryer is making a horrible noise!
heatman101
3434gd
Jun 12, 2010 | GE DBXR463GD Gas Dryer
Dryer makes loud noise is a ge has thin belt on it. belt is ok seems like the tub doesent turn as fast as it did.
heatman101
whn
Mar 09, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
May 20, 2008 | Dryers
GE DBSR453EBWW Electric Dryer Logo
273 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
