Question about Dell Ethernet Card Network Adapter
Problem with my lan port
Hi,i bought my new dell XPS1530.At first it was gud but all of a sudden I cant find LED's blinking when i inserted the lan cable plug into the port.i cant find my system detecting the network(internet).it started all of a sudden.hoping some intaligent one could solve my problem.
  • 1,879 Answers
One end of the ethernet cable goes to the LAN port of your computer and the other end goes to a router's LAN port - both equipments LAN indicator should lit up even with no configuration. try another ethernet cable.
just to be sure that your ethernet card is working properly, click Start then Run and type-in "cmd" without the quotes and hit OK.
DOS box shows and type at the prompt "ping 127.0.0.1" without the quotes and hit the Enter key on your keyboard. you should get 4 sends and 4 replies - else, reseat the LAN card.
Posted on Nov 08, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Dell XPS M1530 won't recognize external monitor
The XPS1530 uses Vista so go to the control panel and choose the port that you have the external monitor connected to. I use an HDMI cable and need to choose both the audio and video separately in the control panel.
Apr 10, 2014 | Dell XPS M1530 Notebook
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Plugged in, not charging. I bought a new charger, a new battery and still not corrected! Is there a software fix?
Try to check your charger adapter LED. If your charger LED is blinking or dim, your motherboard was short on power block. If not, check DC in jack port. Maybe got some cold soldering joint.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Dell Inspiron 1525 Notebook
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
My system does not have LAN facility
get a USB connector that has a LAN outlet on the one end and can be inserted into the USB port of ur notebook, connect your LAN cable to that and ur USB port changes to a LAN port
search in google for "USB LAN adaptor"
Feb 02, 2010 | Dell Latitude D600 Intel Pentium M 1.3GHz...
GSM SIM port in dell inspiron 1420
hi...
the port is for msx12 serial sim... what u else need except the internet sim is the driver in cd which u got along with the sim, the cd contains a driver which will directly make icon on your desktop as a dial up connection, from there u can through the internet, but my suggestion, go for broadband.. dial up.. that also wireless wil not give satisfying speed..
thanks...
viks!!
Nov 14, 2008 | Dell Inspiron 1501 Notebook
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Senao 8610 not working
Are you saving your settings when you exit the setup screen?
Johnlgrn
Dec 29, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
Dell Ethernet Card Network Adapter Logo
246 people viewed this question
Alun Cox
