Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer won't agitate.
How do I know if I have a short cam or medium cam?
  • bandy3 Nov 11, 2008
    washing machine will not agitate
Posted on Nov 10, 2008
Hi, I have a Kenmore Washer Model:110.24722300 70 Series. The agitator is slipping how can i fix this problem and what parts do I need.
Agitator Repair Kit
Item #2744 (OEM Part)
$19.85
Washing machine agitator repair kit with a medium length cam (there are other kits available for different models). This kit should be used when the top part of the agitator is not moving properly but the bottom part is.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285811/2744?modelNumber=110.24722300
Oct 19, 2012 | Kenmore 22422 Top Load Washer
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I can not get the part for my washing machine from the mec! waiting for a year!! Looking for "doggies"
go to most any appliance parts outlet,they have the medium cam dog kit you need to replace the agitator cam dogs
Oct 14, 2010 | Whirlpool LSR5132PQ Top Load Washer
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 16, 2009 | Dishwashers
Washer makes loud metalic clicking/grinding sound when washing and spinning Model number (110.15942401)
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.15942401
There are a few places to check in the washer.
1. The Clutch
2. The Brake system
3. The splines on the agitate shaft and / or agitator
4. The agitate cam and / or gear in the transmission.
Please see the following :
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following is the Whirlpool / Kenmore operations and maintenance manual describing how the washer works and in particular how the neutral drain assembly works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You'll be able to see on the Sears site, the internal construction of the transmission. The Agitate Cams and Neutral Drain assembly cogs are plastic and can wear / break over time.
When ours had a major noise / grinding problem when spinning, we tracked the problem to the agitate cams not lifting the agitate gear high enough (less than 1/16" above the gear on the agitate shaft. Replacing it cost less that $15 vs. $170 for a transmission.
If the Drive Brake, Clutch, agitator splines and agitator shaft seem OK, the problem points to the transmission.
If it appears to be the agitate cams, following is a description of how we replaced them.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Oct 07, 2009 | Kenmore Washing Machines
I need to replace the cam agit for this sear kenmore washer. is it a serviceable piece and if so, what tools do i need?
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Sep 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator makes a ratcheting sound seems to be slipping. do i need a whole agitator or is there a kit to fix this problem?
If this is a Whirpool manufactured washer (includes Kenmore, Estate, Kelvinator, Kitcheaid, Frigidaire, Roper and others), the agitator has a split design. The lower portion is the agitator, while the upper portion is called the auger. Under the auger is a cam drive. The cam acts as a clutching mechanism that drives the auger when the agitator moves. The cam has small plastic teeth called "dogs" that commonly wear out causing the auger to slip. The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link and can be purchased at appliancepartspros.com for about $5. For a little more you purchase the entire cam replacement kit which includes the cam, bearing, any seals, and the dogs.
If this is not a Whirlpool manufactured washer, or simply don't know, please post back with your complete model number (located under the washer lid along the tub rim on most washers).
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 13, 2009 | Washing Machines
When my washer goes into spin cycle it shakes real bad and makes aloud noise. I have leveled it but it is still doing it
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
We had the same (plus another) problem with an old Kenmore top load, direct drive,neutral drain washer.
Problem 1. Major gear sounding grinding during spin mode. Major vibration also.
After checking motor coupling (a bit worn but intact), drive block (you don't need a spanner wrench to remove it, a 12 - 14 inch pipe wrench works great) which was OK, clutch, seemed OK, we determined that the problems were in the transmission.
Two options, 1 spend $150 plus for a transmission.
2. Open it up and see if anything seemed seriously bad.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
the problem seemed to be related to the agitator cam and cam follower not raising the agitator gear high enough (probably less than a 1/16th of an inch) above the agitator cam.
Found the right part number (Whirlpool part # 62580 / 81) which includes both the cam and follower. Bought one for about $10.50, installed it, put washer back together and problem was solved.
Put the washer back together and I now have a happy wife. Everything works as it should.
NOTE. Fixing the washer takes a little mechanical ability (wrenches, socket sets, screw drivers, vice grips, short pipe wrench) and a solid desire to save some money.
All told parts cost less than $20 (I also replaced the old transmission oil with 80-90 weight oil from an auto parts store) saving over $125.
Sep 06, 2009 | Kenmore Washing Machines
Have Kirkland ''Signature'' washer that's maybe 5 years old. It does not agitate. Pulled the top cap off , (and then the inner seal), looked inside to see what was going on down there and AAAAAhhhhh! Dogs...
Hi, Just replace the dogs. Once you remove the 7/16" bolt, the agitator will seperate.
The dogs are the same part# on all models.
Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
