Question about Acer Aspire 5500 5570-2609 Laptop
Acer aspire video hardware error
Good day to you sir, hope you doin fine...
i got a problem with my acer aspire notebook quite semilar with ih8acernow but not as complicated as it seems. It's like the fisrt stage of his problem as stated on his post.
My screen will turned completely black in about 10 minutes when I'm watching a movie/video from the internet with the full screen mode but i can still hear the audio from it. It aslo occurs when I'm having a video chat using skype or yahoo messenger, it will suddenly stopped or froze then the screen turns black yet i can still hear the person on the other side and they can still see me, weird...
I can't do anything, except restarting my computer.... long press the power button then the windows starts at the safe mode.
Reports Problem and Solution gave me some of the available solution of my problem but unfortunately nothing seems to work.
I did try to update my display adapter which is NVIDIA geforce through windows automatic update and on the NVIDIA website itself but it says that i have the latest driver installed. I tried the windows hardware error tools, checking for error on my disk, nothing. I did System Restore countless times already.
Its been four months now, i got this problem on the first week.
Thanks a lot sir, and i hope you can help me with this...
More Power !!!!!
airnox,
erwin_editha@yahoo.com
    Guru:
  • 859 Answers
I just wanted to take a moment and acknowledge your request. It sounds to me, on first instinct, that your video encoder/decoder software components may be or probably is faulty and or just not up to date. A hardware video display adapter such as your Nvidia Geforce Go also has a video encoder/decoder chip. Either one or these two, both dependent on the other, may be at fault. I'll send you a link later with a package to download and install that will update your encoder/decoder set. This set of software instructions installs as a package and is not usually available from MS update or from Nvidia as an update. Why this continues to be so baffles all we techs. Fortunately the package is free and published by members of the free software open source movement.
Just realized that this *still*, may be a hardware fault where your laptop is trying ot go into screen saver or monitor blank as a power saver and is failing at the point where it should realize you have an open tunnel on the IP band that Skype and IM programs use. By failing to recognize you are using display resources while Windows is otherwise not busy, that when Windows wants to initiate a Screen Saver mode or blank the display driver this *failure*on Windows part to Check for Open Applications is also likely to be at fault. This error is hardware related and thus causes the system *hang up*. If it were at the software level, you'd just loose your tunnel session in IM or on Skype and you'd have to restart the app.
It is not easy to express this issue as I see it in general terms. So, I apologize it you are confused. I'll find the encoder/decoder package and post that to you a bit later after I get some more data from you. Would you tell me if you have Vista or XP and what SP version you have? Press these two keys at the same time to have this info displayed, "Windows Key" + "Pause" key. You'll also see info on your notebook builder and how much RAM you have onboard.
Do you also have an independent Memory Manager running? And, what are your Screen Saver setting, and what screen saver runs, then what is your Power Scheme setup? Do you have monitor off set for something similar to the duration of your screen blanking? Often there are setting for this not only in the Windows Control Panel Display module but also, when you startup your laptop you can press Del, F2 or F10 what ever hint you see in the upper area of the screen during bootup for a key press to enter System Settings. In side the system settings is a page where you can set display time outs for battery savings. Check those and see what those numbers are and send those to me also.
Then, if this weren't enough, Acer has this EPower module, usually displayed as a green bar or stripe in your system tray where the digital clock is located. EPower steps down the processor (CPU) clocks depending on your task. It can actually step down your processor speed to as much as 700MHz. This EPower module is rather infamous for causing problems for apps that need full processor speed... much like what you are wanting to do.
Use the comment text area entry box below to comment back to me. Ask me any questions you need to gain clarification on what I've just discussed before we move forward from this point.
Please realize, there is a good chance I can assist you in solving this problem. There is a good chance I may ask another Expert and friend of mine to confer on your problem and lastly, this may actually be narrowed down to a hardware fault, but if so, I will assist you in what to state to Acer and what data to include in a call for warranty service.
Regards,
Worldvet
Posted on Nov 08, 2008
2 Suggested Answers
  • 2427 Answers
SOURCE: help, video hardware error
yes!! firstly consider the power saver issue located in the display setting.. its located in the control panel or simply right click on the desktop and select properties or personalize. it that fails please let me know and we can proceed further!!!.
Posted on Nov 13, 2008
I have one aspire d260 notebook, but i try to recovery to original factory, i read one error dont complete the instalation. what can i do
Good Day Mcontreras!
Can you tell what operating system you are using? It may be possible that your Recovery disk is already corrupted.
or
Recovery disk detected a hardware error on your notebook preventing the restoration point.
Jul 13, 2011 | Acer Aspire One PC Notebook
How to remove bios password from Aspire One AOA110 hello sir, i have Acer Aspire one AOA110. when i press F2 and want to enter in setup it ask for password. now i dunt know the password so kindly tell me...
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
Here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
Cmospwd - Cmos password recovery tools
Hope this will for you :)
Thanks
May 04, 2011 | Acer Aspire One AOA110-1588 Notebook
Won't recognise CD drive
This can be caused by operating system errors use this FixYa Fix, this will only work if the BIOS can locate the hardware during the POST
http://www.fixya.com/support/r3866336-help_ve_lost_drives_in_windows_explorer
Dec 06, 2010 | Acer Aspire 3000 Notebook
Hello sir, mere pas Acer Aspire one 250 notebook
1.use the recovery option by alt+f10 to recover the your os.restart your machine and continuosly press ALT+F10 and choose the factory restore option.
Nov 17, 2010 | Acer Aspire 4720 Notebook
Acer aspire one crystal eye webcam don't work worked for 5 min then quit can't find on computer at all
Mine was a hardware issue after many wasted days trying to figure this out.
I tried everything but I fixed it with a hardware fix.
http://aspiregemstone.blogspot.com/2009/02/how-to-dismantle-acer-aspire-4530.html
This might apply to other similar laptops...
Aug 04, 2010 | Acer Aspire One PC Notebook
ASPIRE4730z says ''Camera Not Found!''
hello sir,
Its a common problem with all the Acer Camera enabled laptop's. even its the same case with mine.
Dnt worry sir, moving ur lapptop not only form one room to another but from country to another wont boz any harm. well to fix the problem u just, try installing Suyin driver, 2-3 times.
I did 4times , n on 4th time I got it.
its my personnal experince sir.
hope it works wit u.
If u feel my solution is helpful, then plz vote r rate me sir.
thank u very much SIr.
Mar 29, 2009 | Acer Aspire 4720 Notebook
Help, video hardware error
This seems like a windows power saver issue. One of the many settings for windows power options is the option of how long to remain idle before turning the monitor off. Issue is that XP and Vista both have issues recovering from this state. First solution to try is to turn off this setting. In either XP or Vista the power options can be accessed from either control panel or on the Screen Saver secton of the desktop personalization.
Nov 07, 2008 | Acer Aspire 5100 Notebook
Acer Apsire 3680
Good day Sir, try the link below there's a lot of video card for acer hope this will help you.
video card
thank you.
Nov 02, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
349 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
